Ethanol free 89 vs 10% Ethanol 92
1 Post
St. Jude Donor '14
Someone told me Wawa carried ethanol free gas. I was disappointed it was 89 and not 92 octane.
Which would you use?
I have a 10:1 compression and Edelbrock RPM package.
I would use the Ethanol Free fuel instead of the ethanol fuels if possible. 3 things happen with Ethanol fuels, Rust in the fuel tank, very hard on older rubber gaskets and seal in the carb and attracts water in the fuel tank causing other problems. StaBil just came with a preventative this year called StaBil 360 which will prevent water in the tank and rust.
I have used StaBil for many years to stabilize the fuel so it does not go bad and also used HEET in my tanks when I put the to bed for the winter. Sounds more like a commercial now StaBil 360 will prevent corrosion but you still need regular StaBil to keep the fuel fresh in long term sitting. I would like them to do a product that does both for classic cars.
http://www.sta-bil360.com/
Do not know about the gaskets but if you bought a rebuild kit for the carb that is compatible with Ethanol fuels you should not have a problem. When I went to buy my Rochester Rebuild kit for my 1977 QuadraJet carb I made sure it was compatible with Ethanol Fuels and said it on the packaging.
1 Post
St. Jude Donor '14
I used to add stabil to my motorcycles because with my short rides they could make if for a couple of months sometimes on one tank of gas.
I can't seem to take a ride without burning up 1/4 tank with this vette so no danger of g as getting old. I do have a hard time staying out of the pedal for the whole ride
As for water collection causing the sky to fall and massive corrosion, here's a look inside my gas tank that's seen nothing but E10 for the last twenty years. The car sits for six months a year during the winter, no stabilizer added. Adding Heet or similar is redundant as the ethanol itself does an excellent job of absorbing moisture (if any).
My cars sometimes sit for months and I have no issues either.
My snow blower sits for 9 months sometimes more and starts right up.
1 Post
St. Jude Donor '14
They do not carry it at all stations I asked at the station while I was there which ones had to and the manager said I would have to check the site. They called it boat fuel on one of their advertisements at the store.
1 Post
St. Jude Donor '14
I just checked their site...
http://www.wawa.com/WawaWeb/StoreLocator.aspx
Go to the locator page linked above. You can select the option to see only stores with the ethanol free fuel available.
Just my two cents here, but ethanol screwed up 5 motors in one season 2 years ago. I had 3 boat motors and 2 Sea-Doo motors out because of ethanol.
After the mechanic pulled my 150 merc's carbs apart he showed me all the gunk built up because of ethanol. I learned my lesson.
If you run a Carburetor, use ethanol free gas. If you have fuel injection, it doesn't matter.
I only use Shell V-power now for all my toys and put whatever is on sale in my trucks.
Ken
Ken
FWIW, I run BP 89 octane in my 10.30 static CR 383 with aluminum heads, without problems. I do have a bigger cam (CC XE274) with a later closing intake, 64* ABDC.
E85 is even worse, see:
http://www.edmunds.com/fuel-economy/...ison-test.html
I wouldn't recommend buying Ethanol ever if you have a choice in your classic car. I don't ever buy it for my normal car either, it's not that I don't support the environment but if I have to burn 10% more fuel plus jack up the price of corn (which jacks up everything else food related), I'm against it. They make it from something besides food I'm all for it, until then no.
