Motor Oil Weight
Motor Oil Weight
I went down to my local Auto Zone and Advance Auto Parts store today looking to pick up oil. I was looking to get Valvoline VR-1 Racing Oil Conventional (Silver Bottle) in 10w-30 or 10w-40. The guy behind the counter said that they don't carry it in the weights I wanted. But they do have it in 20w-50. I want to VR-1 because of its high in zink. My car is a '77 with a stock L-82 with 38,000 miles. Is the 20w-50 to heavy of an oil for my engine or will it be just fine...
I think Pennzoil has extra zinc.
I can't remember where I read the testing. Try searching the forums, this subject has been talked about before. I just did a quick search and found this thread.
http://forums.corvetteforum.com/c3-t...st-data-9.html
20W-50 is too heavy for your engine's needs. 10W-30 in regular oil or 5W-30 in synthetic would be better for you.
BTW, Wal-Mart has better selection and better prices....
I live in Florida and have been using Castrol GTX 5w-30 in my 82' Vette, 86' el Camino and 76' Triumph motorcycle for over 20 years with no problems. Big thing is to change your oil regularly and use the biggest filter that will fit on the vehicle (except the motorcycle which has no filter, just a screen to keep the big pieces of metal from circulating).
PS - your avatar looks cold.
If you go to the C3 Tech Performance page on this forum there is a sticky regarding oil weights and testing. I use 0W-30 full synthetic, and have had no issues. I began using that based on some things I had read in that sticky. Massive amounts of information there...enjoy.
John
John
To Pacecar,
here's my logic.........My NAPA here in town can't get the lighter weight VR-1, I have asked and they have requested it - not available on their system. Like most items/prices you guys can take for granted at your local auto parts store/speed shop; they're not as readily available up here - unless of course you want to pay a roughly 300% markup with shipping/duty charges. The trade off for me is I want the higher zinc, don't want to add an additive, and can't get Amsoil, Joe Gibb's, Royal Purple, etc locally.
My car has the original old L48 in it; runs great as is, and I plan on keeping that way. The hot summer days where she may be out for a 2 or 3 hour run have temperatures in the high 90's usually with some high humidity thrown in, so engine temps run around 200. My cooling system was replaced two summers ago (rad, pump, hoses); and I realize that tolerances on my 36 year old, approx. 145,000 km, never opened engine are not what they used to be. The 20W50 may not be ideal; but until the powers that be decide that engine has had enough, and quite honestly I don't see that happening anytime soon, that's what she'll get every fall before she goes to sleep for 6 months.
Whether the outside temp is 30*F or 100*F, the engine still runs at the same temperature (assuming that you have a decent cooling system and the thermostat is the stock unit); so that means NOTHING to help answer the OP's question.
Higher weight oil means LOST POWER from frictional losses in the engine. That's why the manufacturer recommends a SUITABLE oil weight for your engine.
Anyone can run anything they want in THEIR engine. But, it only makes sense to use what it NEEDS. The lubricity and film strength of synthetic oils allows that thinner oils can be used, resulting in equal protection but lower frictional losses (and engine work). But, synthetic oils cost significantly more. So, use the type oil that you think is best; but go with the weight recommended by the mfgr.
John
John
higher weight oil means lost power from frictional losses in the engine. That's why the manufacturer recommends a suitable oil weight for your engine.
Anyone can run anything they want in their engine. But, it only makes sense to use what it needs. But, synthetic oils cost significantly more. So, use the type oil that you think is best; but go with the weight recommended by the mfgr.
EXACTLY my point, thank you.
Premium Supporting Vendor
I feel that the higher viscosity is only necessary in applications where the bearing gaps have been intentionally increased, or the oil runs at very high temps (260F+). At high oil temps the 50 grade will have similar viscosity to a 30 grade at normal oil temps. In my C5 Z06 at the track, I have a good cooling system and run a 10w30 racing oil (with stock bearing gaps).
AMSOIL does offer this high ZDDP 30 grade oil for applications like the C3:
AMSOIL Z-ROD 10w30 Synthetic Motor Oil (Product Code ZRTQT)
(zinc – 1440 ppm, phosphorus 1320 ppm)
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
