Question - Rear Spring
Old 04-12-2014, 07:22 PM
AF_Vette
AF_Vette's Avatar
Default Question - Rear Spring
I am getting ready to swap the rear spring. Is the procedures that same as a steel spring. ie bolt spring to carrier, install TA bolts to end of spring. Lower car to apply pressure to spring. Tighten and torque bolts to carrier.
Vito
Old 04-12-2014, 08:09 PM
Les
Les's Avatar
Vito
You got it. Two things to remember though. If you're installing a composite spring (I just put a VB&P composite on mine) you'll want to check torque again after each drive for 2-3 times. I found that mine needed re-torquing after each of the first 2 drives. Also, VB&P cautioned about overtorquing the 4 carrier bolts. They recommend 40-45 max, using increments in a pattern to get there. I started at 30 and worked up 5 at a time.
Old 04-12-2014, 10:09 PM
AF_Vette
AF_Vette's Avatar
Thanks Les.
Old 04-12-2014, 11:27 PM
wilesre
wilesre's Avatar
I had an issue with mine where the composite spring stays higher to the frame as it approaches the suspension. Caused it to go very close to my aftermarket exhaust. Had to modify the exhaust. Something to watch for.
Old 08-13-2019, 05:42 PM
kodpkd
kodpkd's Avatar
Also remember,,,,,, your ride height is ONLY dependent on the length of the bolt on the end of the spring. Longer,,,, it sets lower, & vis versa.
Old 08-13-2019, 06:21 PM
Mooser
Mooser's Avatar
Received 3,138 Likes on 2,069 Posts
hopefully he's got it by now
M
Old 08-13-2019, 11:45 PM
RJ1AZ
RJ1AZ's Avatar
Location: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
M
5 years....if it ain't done by now, it ain't getting done.
Old 08-19-2019, 10:30 PM
nwav8tor
Old Fart Pilot
Support Corvetteforum!
nwav8tor's Avatar
Hi Vito, Been a long time since I've seen you on Tim's forum... How's things going on the rock?
Paul
To Question - Rear Spring
Quick Reply: Question - Rear Spring
