engine oil dipstick
Old 04-20-2014, 05:41 PM
llabesab7
llabesab7's Avatar
Default engine oil dipstick
My 74 vette is not showing any oil on the dipstick. My oil pressure is fine and I have no leaks. Am I putting the dipstick in wrong. I notice that it doesn't go in as smoothly as some cars. Thanks
Old 04-20-2014, 05:48 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Is this a late "April Fool's" joke? If you don't see oil on the dipstick,
ADD OIL!
There are 4+ quarts of oil in a SBC sump. If that oil is low by less than 2 quarts (still way too low), it won't show on the dipstick but the engine will still have oil flowing and building pressure through the pump.
Do you ever check it?
Old 04-20-2014, 05:57 PM
llabesab7
llabesab7's Avatar
I do check it. I'm not losing any oil at all. could the dipstick be the problem?
Old 04-20-2014, 06:01 PM
blunblk68
blunblk68's Avatar
may be slowly burning some that you are unaware of??
Old 04-20-2014, 06:02 PM
Conrad Celinski
Conrad Celinski's Avatar
I say its time for an oil change and make sure you put the right amount in. Then check the dipstick
Old 04-20-2014, 06:41 PM
llabesab7
llabesab7's Avatar
What could be causing the oil to burn?
Old 04-20-2014, 07:49 PM
69bones
69bones's Avatar
St. Jude Donor '14
Ok, I'll bite... Have you ever seen oil on the dipstick? How do you know you're not losing it if it's not measurable?
I agree... Change it and watch it.
Old 04-20-2014, 08:03 PM
billcarson
billcarson's Avatar
don't be kidding about missing oil boy it just ain't right.
Old 04-20-2014, 08:11 PM
llabesab7
llabesab7's Avatar
Could it be the ring and pistons?
Old 04-20-2014, 08:13 PM
wilesre
wilesre's Avatar
My Suburban burns a couple quarts between changes. No leaks. No blue smoke. I'm guessing worn rings. Just a tiny bit each revolution. Just started this winter. I did a compression check about 10,000 miles ago and everything was cool. No change in running condition. Planning on doing another compression check (and check plugs) as soon as it's convenient. I guess my point is: check your oil frequently, even if you think everything is cool.
Old 04-20-2014, 08:17 PM
llabesab7
llabesab7's Avatar
will do. thanks
Old 04-20-2014, 09:38 PM
Mike Ward
Mike Ward's Avatar
Before somebody talks you into doing a frame off resto, why not just add oil till it registers on the dipstick then monitor consumption?
Old 04-20-2014, 09:47 PM
gdh
gdh's Avatar
I'd change the oil and filter putting in the correct amount, check the level on your dipstick. If still not showing up measure your ds.
Old 04-20-2014, 10:05 PM
llabesab7
llabesab7's Avatar
Its a new dipstick. It took two more quarts. Its burning it somewhere. no smoke out the tailpipe. May be rings, I don't know. If its not one thing its another. If it needs rebuilt whats the cost?
Old 04-20-2014, 10:15 PM
Lupigiato
Lupigiato's Avatar
How long have you had your 74? Has this happened before or it's the first time you ever took notice of a dry stick?
Old 04-20-2014, 10:21 PM
llabesab7
llabesab7's Avatar
Had it since October. Needed a new cam and lifters and I had my mechanic up grade the suspension. That's about it. Never really thought I would need to check it
Old 04-20-2014, 11:58 PM
Sunstroked
Sunstroked's Avatar
Wait a minute here. A new dipstick? Now just just so you know, there are different lengths to them. If you bought a dipstick from an auto supply store, they usually come with a dipstick tube as well. Did you check the length of the new stick against the original? Did you simply install the new stick in the original tube? This problem may simply be you have a stick designed for a short tube in the original, longer tube.
Old 04-21-2014, 01:29 AM
7T1vette
7T1vette's Avatar
This has to be a "leg puller"....
Old 04-21-2014, 03:08 AM
Dustup7T2
Terrorizing Orange Cones
Support Corvetteforum!
Dustup7T2's Avatar
OK, I'll bite.
Especially with any motor vehicle installed with an internal combustion engine, transmission, suspension, electrical or braking systems... there is surprising information developed by the manufacturer and printed in the owners manual on regular maintenance schedules. By chance, did you receive one for your car when taking ownership?
If so, you will find a chapter or a table dedicated to maintenance interval periods, usually by mileage accrued or by time expired, on when to check certain sub-systems.
Really, it would be to the car's and your financial benefit if you could periodically, review that data.
It would help you more than some of us can, to begin the troubleshooting by establishing a solid foundation of where the problem lies, new dipstick notwithstanding.
Let us know what you determine. Good luck.
To engine oil dipstick
Quick Reply: engine oil dipstick
