water pump
Old 04-20-2014, 07:40 PM
tomgaz
tomgaz's Avatar
Default water pump
I am in need of a water pump. Is their a difference between a 68-69 year and a 74? I am looking at a chrome one for a SBC. Thanks
Old 04-20-2014, 08:30 PM
Ironcross
Ironcross's Avatar
They are basically the same application...If I recall some need fittings usually supplied if necessary that extends the application years...the new ones for the better part have dual mounting holes for the clutch fans and bushings for the pump shaft...again if necessary
Old 04-21-2014, 03:30 AM
Dustup7T2
Terrorizing Orange Cones
Support Corvetteforum!
Dustup7T2's Avatar
Use the following pictures for the dimensions needed in a SB application for our C3's:
This what non-Corvette SB applications use most:
Hope that 'splains the differences between the two.
Good luck.
Old 04-21-2014, 07:57 AM
gbvette62
gbvette62's Avatar
Received 2,022 Likes on 1,312 Posts
Chevrolet changed their water pumps in 1970.
Early pumps had a 5/8" shaft, and a 1 3/4" bolt circle. From 70 on, the pump shaft was 3/4" and the fan bolt circle was enlarged to 2 1/8".
Most aftermarket pumps, have 2 sets of bolt holes, to accommodate both the early and late bolt pattern clutch and fans. If your buying a pump listed for pre-1970, make sure that it has the dual bolt pattern, or you'll likely be replacing your fan and clutch, too.
Old 04-21-2014, 09:51 AM
Dustup7T2
Dustup7T2's Avatar
I stand corrected.
Thanks, gbv-62.
To water pump
Quick Reply: water pump
