1979 L82 auxiliary fan switch help
Hi guys, I have a 79 L82 and have been working on completing the wiring in the engine compartment. I bought a new starter harness and have the wiring intact but need the actual temp sending unit to plug in to the double prong connector that goes to the fan. fan works, I just can't seem to find the sending unit that plugs into this connection. I've looked at Willcox, eckler's, autozone, oreilly's, and all over the internet, but only seem to find senders with single prong connections.
any help would be appreciated.
Thanks,
Gary
Thanks,
Gary
The double prong temp sending unit is for the oil temp... Try your search again under that criteria... I ordered and plan to replace mine tomorrow... Was around $50 somethin bucks... And my electric fan is tied into that sending unit as well... Accidentally jumped those wires when trying to test my gauge and got the electric fan to kick on...
Received 1,469 Likes
Cruise-In II Veteran
The temp switch for the auxiliary fan is on the passenger's head between #6 and #8 plugs.
thanks guys...this is a new engine that doesn't have the switch. I figured out where to put it, and how it works, I just can't find the actual part. Everything seems to be a single wire setup and my harness is for a two wire switch....is there a way to make a single wire switch work with the factory harness? If i run the blue wire to a single prong switch will it complete the circuit once the switch grounds or is that how it even works?
