Vacuum hoses on manifold
Im looking for a good vacuum hose diagram for the vacuum hoses on the manifold that go to the Quadrajet carb on my 1970 350/300HP. I purchased the car and not sure they are in the right inlets. A photo would help if anyone has the same model. The PVC hose is a no brainer for me but the other ones might be installed in the wrong inlets. Just want to be accurate Thanks.
https://www.google.com/search?q=vacu...ms%3B801%3B580
http://www.autozone.com/autozone/rep...00c15280083688
In reality Google Search is your best friend and looking at many diagrams this one will help but there are so many more. Just attempting to point you in the right direction.
Received 1,468 Likes
Cruise-In II Veteran
You may want to consider purchasing the 70 assembly instruction manual (AIM). The AIM shows all the various hoses, routing, connections, etc.
Do you have a 70 owner's manual? If not, order one when you order the AIM.
It may make difference too, if it's the car was originally built for states like California where the emissions were different than those for other parts of the country.
