Zz 427
Old 05-30-2014, 11:30 AM
one-72
one-72's Avatar
Default Zz 427
Repowering time has come.Can I hear any comments about the gm 427/480hp . on researching i find conflicting statements on the cam specs and the horsepower output if you compare the Zl1 it uses the same components other than the block it only claims 430hp and somehow they tweeked the dyno chart to show it. what gives? Aluminum block is only a weight savings .Compare Summit to Jegs you will see the specs are different but the part no,s are the same Thanks.
Old 05-30-2014, 12:11 PM
qwank
qwank's Avatar
The zz427 is a good engine, but you're paying for the 427 name plate. The zz454 and zz502 are much better deals
Old 05-30-2014, 12:26 PM
bashcraft
bashcraft's Avatar
I have the zz502. You'll be happy with it.
Old 05-30-2014, 05:03 PM
gdh
gdh's Avatar
My ZZ383 arrived a few hours ago, know a few ppl with the ZZ502 and they are very pleased with them.
Old 05-30-2014, 06:11 PM
flyeri
flyeri's Avatar
I think it was Car Craft that had an article on the ZZ454. After a couple break in runs on the Dyno with the recommended 4 degrees initial timing they increased the initial and brought the total advance up to 36 degrees. A bit bigger carb, can't remember what size, and they made 500-505 hp. Not too shabby.
Old 05-30-2014, 06:22 PM
qwank
qwank's Avatar
be sure to make a thread with lots of pics
Old 05-30-2014, 06:58 PM
harris1507
Support Corvetteforum!
harris1507's Avatar
A ZZ502 is the way to go, I would have the zl1, but I can't justify the cost next to the zz502, you can go on my youtube channel and see and hear my car, (LeMans Blue). You do need to change the oil pan, and I think the newer zz502's have a mech. Fuel boss. You can use regular pump gas with all the power you could ever use, unless you are racing. PM me if you want more info. Are you going to be racing or just daily driving and showing?
Harris1507 for the youtube vid's
Good luck keep us posted
http://forums.corvetteforum.com/c3-t...s-opinion.html
http://forums.corvetteforum.com/c3-t...-my-honda.html
Old 05-30-2014, 07:59 PM
harris1507
harris1507's Avatar
Double post, sorry
Old 05-31-2014, 10:13 PM
one-72
one-72's Avatar
Thanks to all for the input checked out the video and went ahead with the 502/502 .m-22 behind it and 3.73 rears mounted in custom strange 9in. axle /w detroit locker .HAPPY HAPPY.
Old 06-01-2014, 02:48 AM
harris1507
harris1507's Avatar
I'm running 3.70 rear with a M-21, I could smoke the tires all day long. But it does run of of stream around 5500 rpm, you may want to up grade the cam, make sure you change the oil pan. This was done by PO
I pulled the engine and changed the oil pan
Old 06-01-2014, 08:50 AM
3JsVette
3JsVette's Avatar
Received 2,490 Likes on 1,644 Posts
Just wait till you drive it.
To Zz 427
Quick Reply: Zz 427
