Is it a real 1971 LT1 Vert?
Sure looks like it, from the tach... I don't know, you guys pick it apart and tell me.
http://boston.craigslist.org/bmw/ctd/4535287181.html
It has 72 amber turn signals in the front. Wreaked?
He says " Most of the original body/paint" what does that mean?
"front disc brakes/rear DRUM brakes" not in 71
Where's the picture of the engine stamp pad?
Has the wrong fuel line for a factory Holley.
Peace,,, moosie
Tough to call.
Looks like the intake is right. Looks like the valve covers are right. A/C delete is right. Hood is right. It is possible to get that engine in a convertible.
There's lots about the ignition system that is wrong.
Block stamp will tell a lot of the story.
Look for "double hump" heads, also. Stock LT-1 heads are a different from 'regular' heads and don't have any accessory bolt holes.
Beyond that, you'll need to pull a lifter, the oil pan, or the heads. 4-bolt main is imperative...forged rods imperative...forged TRW pistons imperative...solid lifters imperative.
A REALLY big one that tells you that you have an LT-1 CAR that might not have an LT-1 ENGINE is the car having 1 vs. 2 fuel lines to the fuel pump. This is a big one that "cloners" overlook...the LT-1 only has 1. The second line is the return line in the "regular" cars that the LT-1 does without.
And, of course, if you have all things that APPEAR LT-1 but you find the return line, 99.7% chance that it is a clone.
My engine builder was confused by the GM Service Replacement heads on my GM Service Replacement LT-1 engine until after we realized it was a Service Replacement.
He was very surprised that I had accessory bolt holes on the face of the heads. And it made a lot more sense to him after we found out the history of the engine.
I took it by extension that original LT-1 heads did not have accessory bolt holes. If I am in error, I apologize and stand corrected.
