Window fuzzies -door glass seals-
Who carries the best replacement door glass seals for a 80?
Doing a door rebuild and already ordering door panels from Al K. But I need to replace the outer seal first.
Who's have you used and liked?
Received 1,469 Likes
Cruise-In II Veteran
My guess is that there is likely to be only one or two manufacturers of these, so attemping to compare quality may be a moot point. Original GM would be the way to go if you could a pair.
