Seat Dying
Old 07-07-2014, 08:39 PM
Jim78SA
Jim78SA's Avatar
Default Seat Dying
I was wondering...If i buy aftermarket seats that are not the same colour as my current seats I assume I can dye them, but would the dye hold up. Could I clean them as I do my current seats? Yes, I know i can buy new foam and covers, but I can buy other seats for far cheaper and more modern.
Old 07-07-2014, 08:49 PM
bondoboy
bondoboy's Avatar
Personally, I wouldn't. A seat is a high wear area. I would think it would wear off quickly.
Old 07-07-2014, 09:10 PM
twinpack
twinpack's Avatar
Jim back in a day when I was young, I had a 1961 corvette and at 17 years old I did a lot of work on the car. I did dye the seats with a spray dye. The dye held up very well, even with repeated wipe downs. I never scrubbed it nor did I need to. I am now doing a complete restoration on a 1968 and will be dyeing the seats as well as other components back to the original Dark Orange color and I am not thinking twice about it. Just do your prep correct, I mean clean it good and clean it again. Use the correct primer from the same company and for that dye. You should not have issues under normal use. Good luck with your project.
Peter
Old 07-07-2014, 09:16 PM
Jim78SA
Jim78SA's Avatar
Thanks! I will. I have a couple of seats in mind. It is just a matter of funds. Not much, but don't know if I want to part with the money at the moment.
Old 07-07-2014, 09:20 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
The answer to your question is "Yes", if you use the right product and prep the seatcovers properly. SEM ColorCoat in liquid form can be purchased at many local area paint supply stores for pro body shops (NOT your local auto parts store ). And, if you don't have spray equipment, you can buy an inexpensive PreVal gas/bottle sprayer that will do the work just fine.
Clean the seat covers well; but I would NOT just soak them in soapy water. The scrim foam (channel foam) built into the seats may disintegrate when doing so, if it hasn't already. It would be best to use a sponge with dish detergent and water (1/4 cup detergent per half-gallon of water) to dislodge any and ALL old protectants, dirt, and crud.
Then do several wipe-downs with plain water to dampen the sponge to assure that all detergent is removed as well. Let dry completely, then shoot two light, covering coats of SEM on the seatcovers. Some folks believe that an 'adhesion promoter' should be shot on the surfaces before the dye. But, I like to do a LIGHT wipe-down with lint-free cloth and lacquer thinner, just before shooting the dye. Works for me.
Good luck
Old 07-07-2014, 09:28 PM
Jim78SA
Jim78SA's Avatar
Awesome! Good info, thanks!
Old 07-07-2014, 10:57 PM
Lakeside49
Lakeside49's Avatar
Default *
If maintaining the OE look is important to you, you can make your faded old seats look modern by having them reupholstered with original Corvette seat fabric from SMS Auto Fabrics in Portland, WA, and have Al Knoch sew them up with fresh new foam, and by having them add the correct cross flags. You've got options... and, decisions. A good problem to have.
Dave
Old 07-08-2014, 05:14 AM
Jasonb86
Jasonb86's Avatar
I just went through this with a set of nice tan leather seats that needed to be black to work for my car. I used the SEM Classic Coat, SEM leather prep, and SEM soap. The project turned out great but took me over a month to complete and was tiring. I would not attempt again.
Old 07-08-2014, 09:57 AM
7T1vette
7T1vette's Avatar
I'm not sure why it took that much time. Remove seats (1 hour), clean seatcovers (2-3 hours), let dry, mask stuff you don't want dyed (30 minutes), wipe down w/lacquer thinner (10 minutes), shoot twice (1 hour), let dry (30 minutes...SEM dries quickly), reinstall (1 hour).
It could be done it in one full day...two at the most.
Obviously, if the seatcovers need some repair, they would need to be removed from the seat and sent out for those repairs. That would take some more disassembly time and "wait" time; but that's not relevant to the time it takes to dye the seats.
Old 07-08-2014, 10:19 AM
Jasonb86
Jasonb86's Avatar
Waiting for good weather definitely slowed me down some. But that said, disassembling 1970 seats at least requires removal of hog rings to access the locking mechanism. I disassembled each seat and components, removed sliding lock mechanism, and cleaned thoroughly with SEM soap and let dry thoroughly. No sense painting over dirt or wet leather. Once they were dry I prepped them and laid on multiple light coats of black. It was a color change (as OP describes) and I preferred not to slather on a thick layer of paint. Once the main color was on I had to try to work it into the grooves in the material and in the piping. When you touch the seat, these areas show right through. These seats were done for a show car not a "Fast-N-Loud" flip and I wanted to take the time to do them right. In the end the results were great but it probably would have been easier to recover. The resulting finish is smooth and even with good coverage.
Old 07-08-2014, 06:45 PM
bondoboy
bondoboy's Avatar
Didn't mean to steer you wrong. It seems many had good luck dying seats. I didn't think it would hold up as well as it did. Good luck with your project.
Old 07-08-2014, 07:16 PM
Jim78SA
Jim78SA's Avatar
No prob, thanks!
To Seat Dying
Quick Reply: Seat Dying
