Change system back to R12 from R134a ??
I'm wanting to change my 78 Corvette air cond back to R12. Are there any problems when changing it back to R12 from R134 ??
I can get R12, I'm just bought my car and someone had swapped it over to 134. Looks like all they changed were the fitting for 134. I'm just not happy with the 134 and really would like to change it back to R12 and wasn't sure what was involved in swapping it back over.
Either refrigerant will do the job... IF your A/C system is in good shape AND the plenum isn't filled up with debris [preventing good air flow]. You would need to run the A/C system a little 'harder' if it had the 134a stuff in it {it's not as efficient a coolant as R-12}, but that should be the only difference. Have your system checked out before you go to the trouble of changing the system back to R-12.
Most times with the 134 conversions you need a slightly larger condenser or use a parallel flow condenser. Since 134 is not as "efficient" as 12, the larger condenser or more efficient parallel flow condenser makes up for the slight efficiency loss.
Also, after 1969, GM reduced the amount of insulation in the cars. The 68 and 69's had a lot of more cabin insulation against engine firewall heat and underbody (floorpan) heat. It's relatively easy and cheap to add this extra insulation to your post 1969 Corvette. Vendors have the parts necessary. I've since added a lot of insulation on the passengers side of the firewall since I have the dash board and dash panels removed.
I've completely removed the factgory AC. In it's place is a Vintage Air modern AC system that fits entirely under the passenger's dash panel.
The evaporator is now inside the passenger compartment...no longer along aside the 1000 degree F exhaust manifold.
