82 Crossfire Injection
Old 07-31-2014, 10:21 PM
frankenbro
frankenbro's Avatar
Default 82 Crossfire Injection
I have an 82 with 40,000 original miles. Runs terrible on ethanol added gas. On a hot day if you shut it of for a minute or two it starts but when you put it in gear it chokes out. If run the idle up for awhile 1min or 2 it will go fine. But have had it die in the middle of intersections. Crank and pump the gas to restart.
Are these normal crossfire problems? If not what can be done?
Old 07-31-2014, 11:34 PM
Drawmain
Drawmain's Avatar
A lot of answers here:
http://forums.corvetteforum.com/c3-t...solutions.html
Old 08-01-2014, 11:37 AM
frankenbro
frankenbro's Avatar
Another thing I forgot. With the pedal to the metal at 4700 RPM it starts missfiring and looses exceleration. Thanks for those websites. I ordered one of the books.
Old 08-01-2014, 08:32 PM
terry82
terry82's Avatar
I would look into a new fuel pump .
Old 08-02-2014, 10:27 PM
Lakeside49
Lakeside49's Avatar
You need to rule out the fuel pump before anything else. When you take it out and put it in turn it to the right 180 degrees - almost upside down then rotate into it's correct position - and life is good. Get a new pump-to-tank gasket - it will need it. I did not do the hyped 1985 pump upgrade and my '82 runs terrific with the stock pump.
Dave V,
Old 08-03-2014, 06:29 PM
wilcar
wilcar's Avatar
On a stock xfire you really gain nothing by going over 4000 rpm or so with the restrictive heads and exhaust. At least that was my experience with my 84 xfire before going with new heads, cam and true dual exhaust...........and a carburetor!! Now it is an x-xfire!!
Old 08-03-2014, 07:12 PM
scorpion18z
scorpion18z's Avatar
Originally Posted by Lakeside49
You need to rule out the fuel pump before anything else. When you take it out and put it in turn it to the right 180 degrees and life is good. Get a new pump-to-tank gasket. I did not do the hyped 1985 pump upgrade and my '82 runs terrific.
Dave V,
I agree with above. Change the fuel pump with like kind and many idle and performance problems disappear.
To 82 Crossfire Injection
Quick Reply: 82 Crossfire Injection
