The 1976 Has a Unique Hood
Old 08-02-2014, 12:35 AM
72and86
72and86's Avatar
Default The 1976 Has a Unique Hood
I'm reading the Corvette Black Book about my 1976 and the description says:
The 1976 has a unique hood.
Really? How so?
Old 08-02-2014, 01:38 AM
Vet76te
Vet76te's Avatar
The 76 does have a unique hood. The 76 still has the hood vent at the back edge in front of the windshield like the 73 thru 75 models. However, it is non-functional. The 73 thru 75 vent was part of the cowl induction system that carried air to the carb. The 76 retained the vent but all the cowl induction portion on the bottom of the hood was redesigned and no longer present. The 76 had a new forced air system that delivered from the front edge of the hood just above the radiator.
The 77 model deleted the vent in front of the windshield.
So, an original 76 hood is unique, but it is interchangeable with all 73 thru 79 models.
Old 08-02-2014, 10:12 AM
72and86
72and86's Avatar
So the 76 hood APPEARANCE is not unique, its the function or lack of function that makes it unique.
Old 08-02-2014, 11:49 AM
Vet76te
Vet76te's Avatar
Correct. The 76 hood "looks" just like the 73 thru 75 hood.
Most people don't notice the difference in the 76 and te 77 thru 79 hoods either. Just the omissionon the air vent grill on the 77 thru 79 models.
Old 08-02-2014, 11:51 AM
Doug Kraft
Doug Kraft's Avatar
Plus that by saying the hood is unique people might consentrate on looking at that instead of the vega steering wheel.
Old 08-02-2014, 04:05 PM
myoriginal77
myoriginal77's Avatar
I thought it was the Vega that got the Corvette wheel ?
Old 08-02-2014, 04:54 PM
Vet76te
Vet76te's Avatar
Technically....the 76 Corvette AND the Vega GT both got the GM "Sport Steering Wheel".
Same wheel that was used on the Camaro Z28, the SS El Camino, the SS Malibu and the Sport K5 Blazer.
The only Vega that shared this wheel was the Vega GT.....which was considered as part of the "Sporty" line up in 1976.
A version of this wheel continued on the Chevrolet sport line up through 1981...last appearing on the 1981 Camaro Z28.
Old 08-02-2014, 05:45 PM
gbvette62
gbvette62's Avatar
Received 2,031 Likes on 1,316 Posts
The infamous "Vega" wheel was used on various different Chevrolets. It probably isn't really fair to refer to the 76 wheel, as the Vega wheel, but we've been calling it that since the 76 Corvette was introduced in late 75.
The wheel was first used in 71 on the Vega GT, and was offered as an optional "Sport Steering Wheel" on 71 Chevelles, El Caminos and Camaros. The standard Vega, as well as the Chevelle, El Camino and Camaro, all used the typical straight across wheel, common to all Chevrolets of the era.
The 78 and later Z/28's, used a modified version of the wheel, that featured a simulated rope wrap around the rim of the wheel.
As far as the 76 hood being unique, I guess it is, but so are the 63, 64, 65, 66, 67, and 82 hoods.
Old 08-02-2014, 06:08 PM
persuader
persuader's Avatar
But wait a minute isn't the locking mechanism on the 76 hood different than the 77? The 77-82 have the strikers on the hood with the latches on the cowl? And the 76 down are the reverse of that? Please some one correct me if i am wrong. I plan on installing that vent on my 77 but if the 76 will work then I will just change hoods.
Old 08-02-2014, 08:10 PM
gbvette62
gbvette62's Avatar
Your correct, the 77-82 hoods use the loop type catch on the hood, while 76 and earlier hods have a female latch on the hood.
Old 08-02-2014, 08:39 PM
Mike Ward
Mike Ward's Avatar
The underside appearance is different. It does not have the '73-'75 ducting.
Old 08-02-2014, 09:09 PM
persuader
persuader's Avatar
I thought so. Thanks
Old 06-30-2016, 08:15 AM
jobber26
jobber26's Avatar
All this talk about hoods, anybody know how to adjust the 1976 hood so it is flush at the windshield edge to the fenders? Mine is about 1/2" high and to adjust it to it's correct height, the hood will not latch... Don't say lower the rubber bumpers in front of the hood pins, I took them off. I even cut the hood pins and springs to lower and that didn't work (bought new ones). If I knew how, I would remove the female latches on the hood and recess the whole fiberglass base/mount area to lower everything, but don't have the skills... Any help would be appreciated. Thanks, and I hope no one else has a hood that looks unlatched all the time...
Old 07-01-2016, 12:09 PM
72and86
72and86's Avatar
Aftermarket hood or front clip? My 1972 hood didn't fit cause I found evidence of a previous front accident...
Old 07-01-2016, 12:19 PM
vettebuyer6369
vettebuyer6369's Avatar
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes on 2,775 Posts
If you really want some help and input, start a new thread that asks your question specifically instead of replying to a 2 year old post within a thread that isnt really related to your problem. No one will see it here.
Old 07-01-2016, 01:21 PM
jobber26
jobber26's Avatar
Default all stock equipment
Hood, and latches and pins are all stock... The only adjustment I am aware of is the hood pins...
Old 07-01-2016, 01:28 PM
jobber26
jobber26's Avatar
Default I don't know how
I have never started my own thread; I don't know how... can you show me?
To The 1976 Has a Unique Hood
Old 07-02-2016, 07:30 PM
jr73
jr73's Avatar
look on the upper left of the previous page and you'll see the "new thread" button and click on it.
Old 06-20-2017, 08:21 AM
jobber26
jobber26's Avatar
Default what about the Monza
Didn't the Chevy Monza get the same steering wheel?
Old 07-14-2017, 02:11 PM
calvin3103
1st Gear
calvin3103's Avatar
Default what hoods can fit on a 1976
I have a 1976 and was wondering if I can use any other hood with or with out? modifications
Quick Reply: The 1976 Has a Unique Hood
