Fiber optic connection help
I have fiber optic lines that are just hanging loose up around my headlights. What is the best way to reconnect these? Can you buy new ends and is there some way to connect them to the old lines? I really don't want to replace the entire lines. Thanks for any help. -Mark
Received 1,469 Likes
Cruise-In II Veteran
Headlight FO lines plug into the rear of the wiring connectors. Older light capsules had a nib on the rear which showed a bit of light which the FO picked up. Modern replacement capsules do not have the nibs.
Received 2,878 Likes
Hi Mark,
You don't really say just what parts are missing for the headlight connections.
Both ZIP and CC have some fiber optic parts individually but I don't know if they have what you need.
Also, is it just the headlight parts or is it the parking light parts too?
Regards,
Alan
Regards,
Alan
Hi Mark, You don't really say just what parts are missing for the headlight connections. Both ZIP and CC have some fiber optic parts individually but I don't know if they have what you need. Also, is it just the headlight parts or is it the parking light parts too? Regards, Alan
Hi MMJ,
Here are the connectors for the parking lights.
Regards,
Alan
Regards,
Alan
Thanks, Alan, great photos. So if I can buy those ends, is there an easy way to attach them? They look like they are crimped on at the factory. And I'm sure the headlight ones were probably crimped into the plug that connects to the bulb also, right?
if the actual fibers are old, mangled, frayed,
get a "New" razor blade and squarely cut about 1/8" off the fiber optic.
it will work just fine like this, use a flaslight to test the fiberoptic cables.
if your careful you can remove and reinstall the crimp ends.
good luck,
good luck,
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
good luck,
good luck,
http://willcoxcorvette.com/advanced_...keywords=fiber
Front http://willcoxcorvette.com/product_i...ducts_id=28271
Rear http://willcoxcorvette.com/product_i...ducts_id=28270
Thank you! Will be the next thing I order.
