New 1980 C3 owner! Have some questions!
That reminds me of an old saying
"if you have an enemy don't kill him give him a used car!!! "
In this case give him a messed up Vette. I am sorry to say but I agree with the rest Get rid of this car and find a better car. You could always use this as a parts car.
Not to beat a dead horse, but if you're not going to just use it for parts passing it up might be the smarter move. Better off parting it out and starting a C3 fund - then put money in there that you'd otherwise be spending on that car.
I'm glad you've got mechanical experience with the '95 Trans Am, but I'm here to tell, you, that C3's are a totally different beast, then your Chevelle, Camaro, Nova or anything else you might have worked on. There are shops, that won't even touch these cars!
While standing around with a group of C3 guys on a Corvette run earlier this year, they unanimously agreed, that they'd rather pull the engine, then pull the dash, that's how tough it can be to work on these cars. We're not kidding you here.
But it's your dime and your time...
Can you please tell me what is so hard about working on a C3. The front suspension is the same as any other car, nothing magical there. The dash is hard to pull out, ever do one on a jeep grand cherokee. The rear suspension, if the rear bearing goes you replace the whole arm with a rebuilt one. Now if you had said it is more expensive to work on then I would agree with you.
If you have experience working on cars you will have no problem working on this,
Lack of space and access to things. Forget working on it for a minute, just changing a fuse in my '81 requires an amateur contortionist act. Want to change a bulb in the center gauge cluster? Start by removing the seats. Change the rear diff fluid? Start by removing the spare tire...
There is "hard to work on" meaning very difficult or technical, then there is C3 "hard to work on" which in my experience means a long tedious task. Using my light bulb example, it's not difficult to remove the seats, then remove the side panels, then the lower console, then the gauge console, then change the bulb. It's not a difficult or highly technical task, but the amount of work required is tedious so I'd categorize changing a gauge cluster bulb as hard.
Before someone jumps in, I'm sure there is some easier way to change a bulb by coming in from the back through one side or the other and feeling your way to the bulb. Just making a point on what it takes to get full access to the back of the cluster.
I wouldn't use the stock rear end parts with the big block. if it's an automatic it has all those tiny weak u joints and of course has the aluminum rear diff either way. he'd be better off swapping to an iron diff or at least have the aluminum one built which is going to cost him around $2,000 to have it done right.
I worked at Chevy and Ford as a mechanic for about 12 years, a car is a car. You figure out the best way to work on it.
I'll agree that you have to figure out the best way to work on it, but that can be a tough experience with the C3, compared to your average 60's Camaro, Chevelle, Nova or Impala. We've worked on a variety of cars and the C3 is the toughest, especially the interior and the other things I mentioned, like pulling the trans, headlights, parking brakes, electrical and so on. We've worked on C4's as well and the brake booster is pretty frigging hard work on those and most of the guys who've done it, will admit that.
For those posting about the C3, if they're a beginner type mechanic or don't have a lot of the advanced skills, necessary to be 'smarter than the part' (my brother is the Service Manager and former Master Mechanic at a Ford Dealership), then they're likely going to be frustrated with the access and other built-in difficulties a C3 presents.
And that's why I'll continue to advise those getting a C3 for the first time, that it's not going to be as easy working on these, as your average muscle car. It's easy to say a "car is a car", but that just generalizes everything. If I was on the Ford Retractable forum, or the Lincoln Continental forum, I sure wouldn't go on and tell those guys, the retractable roof is a breeze to fix and adjust, or the convertible top on the early 60's Continentals is easy, because, after all, a car, is a car, right? I have a lifelong friend who expertly restores English cars, including Austin Mini Coopers, and I'm sure he'd have a lot to say, about a car, just being a car, because they're all unique and have their unique set of skills, tricks and outcomes associated with them.
Technically any 1963-1982 frame would and could work with some modifications. However, the automatic frames are the ones with the removable cross member. You should look for a later C3 frame than an older C3 frame. The front ends are different. So finding a frame close to your year model would be ideal. I have found frames as cheap as $300 bucks on craigslist. Post lots of pictures of the build.
TheCorvetteBen
Technically any 1963-1982 frame would and could work with some modifications. However, the automatic frames are the ones with the removable cross member. You should look for a later C3 frame than an older C3 frame. The front ends are different. So finding a frame close rot your year model would be ideal. I have found frames as cheap as $300 bucks on craigslist. Post lots of pictures of the build.
As someone who has almost completed this journey, I must agree with the majority opinion on this thread. Unless you have an intense attachment to this particular car, use it as a parts car and find another '80 with a decent frame from the start. But if you're determined to go ahead with restoring it, expect to spend more than 100% what the car will be worth once it's finished.
#34
good luck sounds like a lot of fun. just do baby steps tackle one thing at a time not all at once it can become frustrating real quick I've been working on my car since 2006 looks worse now than it did when I got (outside) but I got the motor tranny brakes and related items all rebuilt or brand new, scraped paint of but decided to tackle the suspension instead as it has started to rattle more now but just take 1 step at a time and keep us posted on progress and remember whatever problem your going through someone here has probably gone through it so the search button is your friend if not theres a bunch of guys with a lot of knowledge here to help or give opinion
#35
Check out Street Shops Frames
#36
We've jumped to a lot of conclusions because of your comment regarding the frame rust. The main (unsubstantiated) concerns here are:
--Possible frame replacement/major repair - not a huge deal, but one in great shape can be pricey, plus not cheap/easy to ship
--Possible birdcage issue with rust - stamped steel structure that basically surrounds the cockpit (windshield frame, door mount/latch, rocker channels, and connects behind the seats) and requires cutting away body sections to access. It's also 4 of 8 body mount points.
--Issues with the floor panels and the required rear floor section - from the pics not sure how battery is mounted or if this too needs to be addressed
--Modified with 454, but are other components compatible or up to the task? How well was the transplant performed? Condition/strength of trans, rear, half-shafts? Brakes and Cooling? Has the steering been altered? Are spring changes required due to the added weight?
--The rest of the car - if it too needs attention, time and money where are you at with regards to your total return on investment?
I think what the forum members are saying is that for the cost to address any one of these items you could buy a decent driver of the same vintage. I'm not trying to discourage you because I don't know your plans for the car...? But, I'd certainly do a thorough look-see and also a little research on planned repair costs vs looking to see what's available in the classifieds...
Hope this helps, and feel free to ask questions...
Rob
Rob
#37
--Possible frame replacement/major repair - not a huge deal, but one in great shape can be pricey, plus not cheap/easy to ship. I've found 2 supposedly rust free locally (within 2 hours) from $600-1300, so we'll see how that turns out.
--Possible birdcage issue with rust - stamped steel structure that basically surrounds the cockpit (windshield frame, door mount/latch, rocker channels, and connects behind the seats) and requires cutting away body sections to access. It's also 4 of 8 body mount points.I'm going to checkout the birdcage this weekend.
--Issues with the floor panels and the required rear floor section - from the pics not sure how battery is mounted or if this too needs to be addressed.
I'll have to double check it this weekend, but I believe it is mostly the driver's side floorpan that needs repaired due to rust. As far as the hatch fiberglass, it was cutout from the front of battery tray to before the gas tank section. I have the front1/2 of this fiberglass which includes the battery tray to the differential.
--Modified with 454, but are other components compatible or up to the task? How well was the transplant performed? Condition/strength of trans, rear, half-shafts? Brakes and Cooling? Has the steering been altered? Are spring changes required due to the added weight? As far as springs, I have a set of new aftermarket springs that are ready to swap, as well as all suspension bushings, etc. I'm an autocrosser, and even though this won't likely become an autox car, the suspension, cooling, braking would have to be upgraded anyway
Rob
Rob
#38
Even if I buy a decent condition driver car, I would eventually do a frame off restoration on it anyway since this is a car we plan on keeping forever, so I figure might as well start with this one, even if it does end up being a parts car. I hope to determine more about it's true condition this weekend.
If you decide to go the full-on resto route, it's going to be years before you drive this car and a whole lot of dough. Just food for thought, because you may end up, easily putting double what it's worth, plus the time, that you could've been driving another Corvette instead.
On the other hand, you'll get quite the education, doing this, that's for sure!
#39
So yeah, finally got around to checking it out this weekend. The passenger side of the frame actually looked pretty good, the driver's side, eh, not so much. It was so bad on the drivers side that when I tried to jack the car up by what I thought was a decent spot in the frame, it just started crushing a little before lifting up. It is rusted all from the back of the door to about 6" inches past where it curves at the front wheel wells. I also noticed that the drivers side engine mount and control arm mount looked to be re-welded on, whereas the passenger side looked factory. I think the car may have been hit on that side at some point. The bird cage looked great I think, at the most there is some slight surface rust in a few spots along the sides of the windshield, the rest looks great, except for the body mounts inside the car, I think it's the #2 and 5 mounts? They have quite a bit of rust, but new body mounts seem abundant online. The rear compartment area, I found "replacements" all over eBay for $2-300, but given I would need floor pans too, at $275 each, so I would be looking at ~900 in parts alone (not counting repair materials or labor) just to get the body back to normal. The 454 engine just needs the carb tuned, otherwise it is good, trans is supposed to be good, and the brakes have all new calipers and lines. So my thoughts are to find a good body/frame C3 with a bad/blown engine, and use this as a parts car for that car, then sell whatever I have left. They seem to go sub $5k around here on Craigslist around here (Louisville area). What do you guys think?
#40
Don't let the exterior of the windshield frame fool you. Honestly, I would have called mine nearly perfect. Even with the dash out of the car the interior portion of the lower corners looked perfect and still painted. It all came to life when my windshield was removed... Complete rotted holes in the upper corners and the lower cor ears were worse.
It's all hidden. That #2 mount is a tell tale for your windshield frame a lot of the times. The water comes in behind the windshield, rots it away, and drips down into the #2 pocket rotting it out. The #2 is the only quick and easy area to visual inspect without heavy disassembly.
