Shorter rear leaf spring
I'm using offset trailing arms and was looking for a shortened main leaf for my 9 x 2.5" leaf spring. I checked with Guldstrand but they no longer make it. I decided to cut mine, no problem but making the 7/8 holes prove to be difficult. What is the best method to make the holes, drill vs carbide bits? Or if anyone knows where I can purchase the shortened main leaf. Thanks for any input.
Nam Labrat
Received 4,173 Likes
Buy some "Thread Cutting Oil" from the hardware store apply it to the metal while drilling the hole.
First......drill a 1/4" diameter hole through the exact spot......use a variable speed drill motor at about 50 to 60 rpm/veryslow (you can practically count the rotations of the drill(bit)!
Use the cutting oil to keep the metal wet.
Next........use the correct size drill(bit) to drill the finish-hole...use plenty of cutting oil.....you may have to use a slower rpm on the large drill. Once the larger drill(bit) is about to go through the spring, press lightly on the drill motor to keep the drill(bit) from "grabbing the metal" and spraining your wrists
Take your time....the spring metal will harden if you spin the drill(bit) too fast......and you will not be able to drill all the way through.
Plan B would be to take the spring to a small machine shop---they are more likely to do the work sooner and cheaper.
I cut the spring equally on both sides which I did for tire clearance. I installed off set trailing arms at the same time. After I bleed the brakes and road test I'll post how it worked out.
For my 68 and 70, I ordered a composite rear spring and ordered it 1/2 shorter on both sides for each car. the composite spring weighs 8 pounds, the steel spring weighs 42 pounds. Also, the composite springs are so much easier to install (safer). My 68 has a Tom's Differential rear end that is essentially stock..although with Tom's hardware and a VBP offset trailing arm. The 70 has what I'd call Tom's Super 10 bolt differential, 31 spline axles, large diameter U-Joints, Offset trailing arm made by Toms. Stainless Steel Brake Corporation aluminum calipers on both cars.
