Rear view mirror falling off..
It has come off 3 times now. I've tried different adhesives, cleaned the hell out of the window, followed the directions and it still falls off.
Anyone have a lead on what to use to keep it glued on?
It is not fun trying to drive these things with that gone. As I'm sure you all are aware, those side mirrors are just there for the looks.
thanks, I'll try that tomorrow. Have to go by one of those stores anyway.
Nam Labrat
Received 4,153 Likes
It's still good after 5 years!
HMMM..razor blade+alcohol=911 call.
Just kidding, I know what you mean.
New blades-check
alcohol-check
marker-check
400 grit-check
Just may try all of that tomorrow, that thing hurts when it falls off and smacks my kneecap.
New blades-check
alcohol-check
marker-check
400 grit-check
Just an update.
Mirror has stayed on for 2 days now. Ran the car around town and hit some "rough" roads.
Used that adhesive from O'reillys, cleaned everything with alcohol, roughed up the metal tab with some sandpaper and stuck it back on.
Hope it stays now.
Hope it stays now.
Nam Labrat
Me too! If it doesn't......scuff up the area of windshield glass where the metal tab will glued on.....use masking tape to protect the surrounding windshield!
If not, drill a hole in your windscreen and bolt the damn thing to the glass...
I thought about it!
Call around to local glass shops.
I have had a few put on for free because it's a "safety" issue.
To buy it yeah have to pay, to glue it on, call around and ask.
They have better "glue" then the parts stores or what you can buy. (or should have)
