Body work help!--ATF on primer
78 Corvette; trying to save money by doing most of the body work. Bad luck, just finished priming and decided to move the Vette out to get some sun. Think the vacuum modulator died, ATF on the manifold and sprayed on the front clip (see pic). Any suggestions on sealing this? Realize I will need to sand/re-prime, but worried it may have absorbed into the fiberglass.
Thanks,
Mike
Thanks,
Mike
Received 1,469 Likes
Cruise-In II Veteran
Strip and reprime. You want to ensure you remove all traces of the ATF.
Mike
yeah. I know only a little about painting as I'm just now buying paint and guns but I'm pretty sure I would sand it down and spray that section over.
Easier to do that for a few days now than to completely strip the front and try color matching paint when a possible issue pops up later on.
Mike
Was the ATF silicone or dino? It might make a difference. I'd use silicone and wax remover first before sanding in order to prevent grinding the ATF into the glass. Use a few drops of water on the spots and look for "beading" of the water. After it's completely clean, wash the entire area with Dawn kitchen soap and flush with plenty of water, then sand and respray.
Your KD2000 primer is an epoxy primer and fairly impenetrable to most solvents. You may be able to simply wash off the surface with a good wax/grease water based cleaner. The unknown here (I have not worked with House of Kolor - I use SPI) is whether 3 days of curing was enough to make the primer hard enough to resist the ATF. Call House of Kolor for info.
If it were me, I'd probable scrub the area multiple times with a water based wax/grease remover, inspect for any signs of staining, and if none, sand the area down to prep it for another coat of primer.
I'd then let it sit in the sun for 30 plus days and re-inspect before putting anything else on the surface.
Appreciate all the responses!
