Is there an tool for this?
Is there a tool for these &^#$% rubber pegs that are supposed to press through a hole? Maybe I'm all thumbs, but these make life miserable. Slather them with soap, spray them with silicone. pull on them with needle nose pliers until they break, etc, etc.
I would buy a tool in a heartbeat to save the time it takes to get these in.
yes, its called a pliers
I just changed my radiator and the old cushions from ZIP have a GM number molded into them. They were hard enough to install, years ago. The NEW ones from ZIP are slightly wider in their outside dimension, to not want to fit inside the metal saddle and the cone "prongs" are LARGER than the GM ones. I had to trim mine down to pegs to install them. Maybe a Dremel would help, sanding them down. And LT-1 kid, the first one that I tried with pliers got no where! These cones are too large to fit through the hole. Lou.
Some times a little lube helps.
Some times there is a hole partially through the peg, that you would use a rounded tool/punch/nail to push the nub in.
You could also use a small screwdriver to push around the edges of the nub to force it into the hole.
Received 3,138 Likes
Assuming it's not tongue in cheek
I find that it's best not to try to pull them in.
A touch of white grease helps, then place it into the hole and grab the through end and bend it over sideways some while slightly pulling, this will pull one side through or almost through, then move the pliers around in a circular motion (not turn - just wobble them) a few times and they will sort of "screw" themselves into place quite easily
On the heavier ones, (such as the control arm bumpers, again a little white grease and press them in from the top, again while turning them and rocking slightly sideways
M
M
M
M
The other thing is if they seem hard, toss them into some very hot water for a few minutes and that will soften them and allow for a bit more give while you coax them in
M
M
Old Fart Pilot
So much for getting them in, I'll worry about that when I get there. Right now I want to know how to get them OUT!!! Is there any way to remove them without just breaking or cutting the end off?
Nwav8tor, If they are old and brittle, the prong is going to snap off anyway. I don't know if anyone makes a better reproduction. I love ZIP... I am one of there longest patrons, before they had customer numbers. Lou.
YES!!! One of one guys on the C1-C2 forum just came up with a tool to do exactly what you want to do and he tells how to make it.
Just follow the link.
https://www.corvetteforum.com/forums...-it-s-for.html
Pure antifreeze will also work in most cases, very slippery.
