Jacking up my 69' stingray to look for dust
It really embarrassing to come ask these question that were probaly taught in basic automotive in high school. SEE that was the class i was already skipping because who would of thought i would live in the real world one day and it would be good to know some basic car knowledge. So somone had mentioned for me to jack it up so we can get a look at the under side. I assume place my hydrolic jack right on the fram by the rear wheel and get it up. i'm not sure what i am looking for except for lots of rust- someone said something about a dogleg? might as well have been speaking French loli really dont think rust is going to be an issue but i wanna rule it out right away. So when i have the jack on it i should i try to get as many pictures of the undercarriage as i can ? i know i rely on your guys alot- i just know how much time i willl save talking with guys who know thier stuff.
Corvettes, like all cars have certain points on the frame in which to position a jack. It is important to utilize those points, and only those points.
Once jacked up properly, you must position quality jack stands (cheap jack stands can be very expensive) at corners of the car where work is being done (or all four corners), if only lifting one end, be sure and block the wheels on the opposite end.
In addition to the jack stands, leave the floor jack making contact, as an additional safety feature.
Manuals for your car, will instruct you where to locate the jack.
Elevating your car, is not to be taken lightly..most of us, who work on cars, and have friends who work on cars, have had friends die, from a car falling off of its support (I had two people I knew).
Safety first!
Safety first!
Received 1,468 Likes
Cruise-In II Veteran
Recommended jacking points are in the owner's manual and the jacking instructions on the jack storage compartment door.
Just take your time and pay attention to what you're doing.
The dogleg is the part of the frame in front of the rear tires
https://www.corvetteforum.com/forums...ks-safety.html
Here is a picture of the rear kickup or dogleg that we are talking about. This is a picture of my car while it was up on a lift when I got new tires this summer. It was taken with me standing under the car. The kickups are directly in front of the rear wheels. You may be able to get a limited look without jacking up your car, but it is far easier to see when it is on a lift, jack stands or backed up on ramps.
Nam Labrat
Received 4,154 Likes
I use the "roll-around" floor jack that can be bought at most auto parts stores for Around $50.......I also bought four jack stands ( a great friend of mine was killed while using the jack that came with the car. He forgot to place a jak stand).
Always take the extra 30 seconds to place the jack stand in a solid location. And take lots ok pic from different angles using a flash or a drop light .
And always ask questions if you can find info by using the SEARCH FUNCTION.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
I've always used the expression "kickup area" in front of the rear wheels. I think this can be the most important spot to check for rust. Below is another clear photo of what the kickup is, the place where the side rail turns upward above the rear wheel. Just imagine on a car the rear wheel being where the brake caliper is.
Look at the side rail for spliced-in sections and look at the rear "cap" for softness or rusting.
Tommy,
I would really recommend then taking someone to look at this car with you. Maybe someone here on the forum, a local NCRS chapter member or other local car club.
I would not skimp on this inspection; get verification from someone who knows that the frame and birdcage are in good condition.
Here is another pic of the same area on my car that is shown in my previous post, but from view that will be easier for you see without jacking up your car. You'll just need to lay on the ground with your head in front of the rear wheel. Please take a good quality picture of this area and uploaded it to this thread so the forum members can give you an opinion about the rust present in this area of your car's frame.
Also, when using jack stands-take weight of car off the jack itself so all weight is on jack stand, using jack as a secondary "catch point". Test stands before proceeding under(shake car to be sure stands do their job).
