Fuel in cylinders and crankcase of my 68 427L71
Help with diagnosing why I have fuel in the cylinders and and crankcase of my 68 427 L71. I went to start my motor the other day and the motor would not turn over. Thought I had bad starter so I changed it and still wouldn't crank although I could tell starter was engaging. I then tried to turn the crankshaft using the crankshaft nut with a socket and breaker bar. Still nothing the motor is locked up. I removed the spark plugs and fuel came out on a couple of cylinders. The motor then turned right over and more fuel gushed out the cylinders and finally dried up. I replaced the plugs and the motor started right up. But I noticed oil pressure dropped off right away. Only ran the motor for 20 or so seconds and shut it down. Then I checked dip stick oil level and found gas in the oil. The level was about 3 inches above the full mark on the dip stick.... quite a bit of fuel in the crankcase....... The gas tinned out the oil and I'm sure that's why no oil pressure. How did this happen and is the motor damaged or just a bit dry ??? Now let me mention this. The day before this happened I drove the car about 50 miles or so. Motor ran strong and hard like a L71 should... Not as much as a hiccup from this motor.... At the end of my drive that evening I filled the tank to the very top. Right to the filler neck (with 100 octane leaded fuel). Drove the car home from filling it up about 1 mile and parked it in the garage. The next morning the motor was bound up with fuel. Could fuel have siphoned up into the carb past the needle valve and leaked past the rings filling up the crankcase ?? The tank in the C3's sits very high. Any ideas to this mystery ???
Yes, very possible and probably that this is exactly what happened. Fix the carb and change the oil before cranking the engine again. Avoid overfilling the tank too.
Not relevant but leaded fuel and 100 octane are not required for your engine.
OP - What carb are you running on the motor?
2nd on hydralock. The first thing I thought of when I saw "crankcase" was bad fuel pump diaphragm, but (partially) eliminated that when I saw fuel in cylinders. Doesn't mean he couldn't have a fuel pump problem and a flooding carb...
