Gas tank replacement
Hi- Is there a gas tank without a bladder that will fit my 75 corvette? Can the tank I have be used without the bladder? If so what does it take to remove the bladder, and is there a interior tank coating needed? If these ideas don't make sense, what is the solution to this problem that allows only 7 to ten gallons in the tank? thanks in advance.......
Nam Labrat
Received 4,173 Likes
Please don't put a coating in the tank.....10 years from now it will start disintegrating and clog the fuel system.
Click on these shortcuts to threads:
https://www.corvetteforum.com/forums...s+tank+bladder
