what engine is it?
Received 1,469 Likes
Cruise-In II Veteran
Looks like a generic small block Chevrolet with aftermarket parts.
It is a Generation I small block Chevrolet V8. If you want to know it's displacement - who knows? It could be 265 cubic inches to over 400 cubic inches. It does not look completely original, so it could have lots of changes over what the factory produced. Is English a second language for you? This engine is basically the same as millions produced from 1955 into the 2000's.
See if you can see any number on the engine pad.
Take a flashlight, and stand on the passenger side of the car, towards the front. Lean over the AC compressor, and look down, there should be a small portion of the block that extends out where the cylinder head mates to the engine block, this is where engine information should be stamped into the block. If you can provide thos numbers, someone should be able to tell you what you have, or at least what the engine started out as.
Received 2,878 Likes
Hi mrk,
Well at least you didn't get yelled at in this thread!
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
Nam Labrat
Received 4,174 Likes
