original Muncie vs 5speed?
So I've never had my '72 454cu.in. on the highway and it is down to bare frame now as I restore it. The original Muncie M20 came packaged with the car but needs a rebuild, so I'm at a crossroad... rebuild the Muncie or go 5speed trans with overdrive. Would be cool to have the numbers matching drive train back but also want a comfortable highway cruiser. I found a RPM calculator on the web and it says I should expect about 3000 RPM at 70mph with 3.36 gears. So those of you with the original 4 speed... what is that driving experience like? Manageable for short highway runs? Thanks!
5 speed. keep the original transmission packed away safely
You want original or modern OD transmission?
The modern trans shifts better, is stronger and has the benefits of overdrive!
The original came with the car and is period correct.
I want original, but that's just me.
It's your car...
It's your car...
Theres another post going on right now talkng about what is Old School. This is where I would show my old school colors.
I am old school. nothing better than listening to my big block/side pipes cruising at 70 mph, 3000 rpms. I love the sound,vibration, I have considered changing my rear ratio, but just do not want the trade off.
I vote rebuild the 4speed, and keeping it old school.
It's a tough one for me. I'd likely do the modern OD trans without a moment's hesitation if money were no object, but it is an expensive mod for sure. I might have to go old school on this one and pretend I don't know any better!
If the money is in the budget, then 5 speed all the way.
If budget is of a concern, getting that muncie rebuilt will cost significantly less.
I do a lot of road trips, car has been to NJ, TX , KY, TN, OK, PA, IL, WI, MN. so a 5 speed made sense for me. I would of gone 6 speed if possible. I keep my 4 speed in the basement. I think overdrive in these cars is the best upgrade. If your not going 80 on the highways around here, go will cause a collision. Driving around town 4 speed was great
Remember the car is quieter on the highway with 5 speed, motor is not screaming. If you like all that noise. leave it in 4th and when you get tired of it (When the wife is with) go to 5th. Best of both worlds.
Just my 2 cents
http://www.ebay.com/itm/89-CAMARO-FIREBIRD-MANUAL-BORG-WARNER-T5-5-SPEED-TRANSMISSION-GM-V8-1352-196-/321591757083?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ae05cc91b&vxp=mtr
4speed vs 5 speed
I rebuilt my Muncie 4 speed and put a Gear Vendors Overdrive behind it followed by 3:55 gears. The motor is a 496 BB with 635 hp. GVO goes for $3,000.00 which is less than the 5 speed. This combination allows you overdrive in 2nd,3rd,and 4th gear. It is rock solid and more fun to drive than anything I have been in.
The Muncie 4 speed is not a problem for me but the stock shifter has to go. That's what makes it feel like you are driving a truck. It will be replaced with a Hurst Competition Plus shifter . A world of difference in smoothness.
3000 rpm at 70 with 3.36 gears is great for about 5 minutes, then not so much. 5 speed you can get a lower first and a higher top end. Best of everything. Save the Muncie for future generations.
