Lower Power Window Manually
If it's actually working, your best bet is to thoroughly clean all the tracks and rollers, as that grease is 38 years old and rock hard. You still need to do this, to both doors, regardless, because rock-hard, gummed up tracks and rollers are the leading cause of Power Window Motor Death or PWMD, a serious condition that has a lot of bad side effects (mainly on you!).
Electrical or Mechanical is what you're going to investigate.
Received 1,469 Likes
Cruise-In II Veteran
Did you test the switch?
Have someone hold the window up (add some up pressure to it) and remove the 3 bolts holding the motor to the regulator.
Remove the motor and the gear and the window should move now.
Thinking a little further on this - the spring in the window regulator will hold the window up and will create more resistance the more the window is pushed down (with the motor removed). Right?
I was a few months ago planning upon replacing my door windows and the power windows "regulators." There are YouTube videos that are helpful.
I now have all new door window glass and windshield glass in my 68.
Windshield glass is NOS and window glass is OEM Pilkerington Classics. Pilkerington now owns the Libby Owens Ford logo that's on C3's.
