Vacuum Headlights??
Vacuum Headlights??
Well I removed my electric headlight Probe conversion to go back to the original setup and have forgot some things. What it's doing is when I first start the car the headlights pop up maybe a half inch then drop back down.
Then with vacuum present I have the lids adjusted flush with the body but when the vacuum escapes and the actuators relax the headlight lids just barely lift and is no longer flush.
And third is in the up position I have up and down play in one of the headlight housings so do I need to turn out the actuator link clevis??
Thanks,
AL
Thanks,
AL
I agree with Batty, vacuum sux, stick with the conversion.....
I lost my '72's stock lights in a DEER wreck back in '98 and so I put in Ecklers trays and taller headlight/squares.......then some Verizon truck backed into my left bumper and took them out....can't win....so I replaced and filled in the huge openings.....
see lights on the sites....
I don't plan on doing anything with them and I went back because to me vacuum is a much smoother operation. I even kinda like seeing one headlight coming up before the other. If I would have been able to slow the operation down I probably would have stuck with them.
The ORIGINAL and bestest
Toronto Events Coordinator
http://www.ebay.com/itm/10-50V-40A-DC-Motor-Speed-Control-PWM-HHO-RC-Controller-12V-24V-48V-2000W-MAX-/370962506627?pt=LH_DefaultDomain_0&hash=item565f16a383
A simple and fairly cheap DC motor PWM controller would do that for you; something like this:
10 50V 40A DC Motor Speed Control PWM HHO RC Controller 12V 24V 48V 2000W Max | eBay
Well to be honest I had the circuit board out of the housing resting against something and when I went and hooked up the wires (temporary) it slid and touched the alternator case so I think I fried it and never bought another one. Do you have a video of yours being slowed down?? I'd like to see anyone's if they slowed them down.
Received 3,220 Likes
Here's the PWM slowing down the plate-
Here's it w/o the PWM-
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Al- Normally when they pop un and then go down the control (small hose) side has lost vacuum. So the likely culprits would be the headlamp relay, the check valve, headlamp switch or the bypass switch.
What is happening.. the default position of the system is for the lamps to raise upward so when there is no vacuum present on the small side the relay starts to pull up the lamp. As soon as vacuum builds on the small hose side the relay pulls the plunger and the lamp drops back downward.
The adjustment issue with the housing fitting differently could be the pivots, or the pivot ends being worn on the actuator bracket. It would also be the bushings inside the headlamps pivot. Most of the time the clevis bushing is worn out but all combined would also cause this issue.
The third issue is in your adjustment... The video we did on the headlamps adjustment covers how to nail this down.
Willcox
Headlamp Housing Adjustment 68-82
Willcox
Willcox
Willcox
I saved that, your diagram makes the vacuum set up look easy and nice,
Thanks for posting that
I'm always amazed when people complain about it being complicated, or difficult to maintain, there's nothing more complicated than a spring in the whole setup. It's just like a simple electric spdt relay.
Okay perhaps it's really a bad reflection on me but the only drawing lay outs I had seen of the vacuum set up looked like a plate of spaghetti, what Wilcox posted is super straight forward and simple,
When My 69 gets back I will re-test the vacuum parts of the system and likely try it because I have it and it's free, my headlights actually worked fairly well before the car went into the shop...
Former Vendor
When I do them I try to keep in mind the kiss rule and I'm sure most of you know what that is. Most of the drawings and schematics I've done over the last 15 or so years are on the web site. Older hand drawn ones I keep in a book in my service department, it's about five inches thick.. (be sure to come to the auction when I croak)
Happy Holiday's
Willcox
Thank you, I love those little charts and simplified the schematics.
Happy Holiday's
Willcox
Happy Holiday's
Willcox
Will you happen to be going to the NCRS in Jan in Lakeland?
Al- Normally when they pop un and then go down the control (small hose) side has lost vacuum. So the likely culprits would be the headlamp relay, the check valve, headlamp switch or the bypass switch The video we did on the headlamps adjustment covers how to nail this down.
I recently had my 68 painted at J&D Corvettes, Bellflower Ca...forum sponsor. (fantastic paint and body work). As part of the painting and body work, they wanted the headlights and windshield wiper door to cycle to prevent any interference/scratching with the body paint work.
Very distressing to me was that a new repro headlight vacuum actuator did not work..it would not hold a vacuum. They replaced it with a used OEM actuator out of their salvage inventory. I think the bottom line here is that if your vacuum system has repro parts in the system, you should be very careful to verify with a Mini-Vac hand held tool that the repro parts work. Well..of course you have to do this if you still have the OEM vacuum parts.
Sorry to hear your electrical headlight system wasn't satisfactory. The vacuum system is very fussy to work with and I'd hoped this would have been a simple, but expensive, solution. Back to the vacuum system I guess...even though it sucks!!!
