Looking for a gas tank with fuel pump
I need to replace my gas tank and am looking to go ahead and convert to EFI.
Can anyone recommend a good tank that potentially already has a fuel pump setup included? Hoping for something as "drop in" as possible.
Thanks a lot for any info anyone has.
Had this been available when I started mine it would be in my car. I had to make my own setup.
http://www.tanksinc.com/index.cfm/pa...rod/prd443.htm
Found this on corvette central the other day.... they sent an email add out and this was on the list.... tank for FI intank pump.
Looked pretty good.
http://www.parts123.com/corvettecent...50g&ukey=AAADH
Looked pretty good.
I have used their tanks many times they are very well made. I just ordered one for my 64 roadster LS1 swap. I will also mention when you run your fuel line use Teflon or PTFE hose. I use the one with braided steel cover. Todays fuel are not nice to rubber fuel hose. I learned the hard way.
I went with a pump to drop in the stock tank, but you sound like you want less fabrication. Just a suggestion, decide on what EFI first so you can get a pump/regulator to match. And, as long as the discussion is on fuel lines, I like the Nylon, or copper nickle alloy, but that's just me. I always was a little different.
Good Luck
Good Luck
I am doing a stock TPI l98 in my 78. Purchased a stock 78 fuel tank, a 82 fuel sender unit and an 86 in tank fuel pump. I am running nylon line for the return ( maybe even do the supply the same way). The 82 sender has 3 wires coing out the top for the pump and the sender. And the sender I got on ebay was stainless with the 5/16, 3/8 and 1/4 lines coiming out the top. No fabbing necessary for that.
Anyone have thoughts about a fuel pump recommendation for my 70 project car? I don't know if I'll run it with carbs or a EFI. Is there a fuel pump compatible for either? It'll have a 496 or 502 engine. I have a Quanta repro tank. It's never been wetted with gasoline, so it'd be easy to have someone weld in provisions for an internal submerged fuel pump.
Thanks for the reference.
