Rear speaker system 73 coup
Just had to subscribe. Had some thoughts on something like this. Your plan roozster, I like it, I won't be going with an amp, but the speaker mount, good planning. Keep us up to date. T
Love to see that installed! I like the speakers angled like that, to maximize the storage space. I`d also be curious if the T-tops will still fit in the back.
I like where your going with this install.
I'm no where near installing a speaker system in my car yet but I was eyeballing the rear area to do a speaker install, after I had remove the carpeting and also removed all the glue off the fiberglass in the rear compartment.
Your set up is looking great so far.
One question, what are you using for your black floor carpet? Parts of floor carpeting sections? Thanks.
I measured and it looks like there will be enough room for t tops with an inch to spare.
I ordered the carpets from ACC and ordered extra bulk carpet.
Got to spend a few hours on the Vette this morning.
got the Fat mat in the rear section and coated the storage area with Herculiner.
Looking good so far! I also used FatMat, then reflectix over that. I had to pull a little of the jute backing off the carpet to get the loops for the t-top strap back in though.
Looks great. I will starting the same project, hopefully, in the next couple of weeks if the weather holds up!
Got the same powered sub for my set up (rockville 10" right? ). Already cut kicks for front speakers and need to remove the dash for the dash speakers. I assume you removed the dash....how was it??
Great job on the carpet as well. Looking forward to more pictures and opinions!
Tom
Tom
Tom
Tom
