no heat in 76
no heat in 76
Opposed to the usual problem of too much heat, I have no heat. I replaced the vacuum control valve in the engine compartment, ran water through heater core to make sure there was no blockage, made sure the water pump was pumping and installed a new 192 degree thermostat.
If I understand correctly, the water control valve is closed under vacuum. I have vacuum at the water control valve, but it is continuous. Therefore, I disconnected the vacuum line thinking the valve would open and I'd have heat. Did not work.
Advance thanks for any help on solving this problem.
Now that's a C3first.
I can bottle up some from my car and send it to ya.Mine makes enough to heat a Greyhound bus.
I would check the engine to be sure it's running
Sorry I nothing useful to actually help. But I' m stumped to be honest.
I had headers on an old 66 BB.....that baby could thaw a hole though an iceberg .
I just never lived anywhere , I had to have car heat .....no sure I want to either
I think if I took every vent ,hose ,duct , heater core and threw it all away .....I believe I d still roast .
