wipers will not seat to close the door on my 71
Hi, I had my windshield changed and figured that I would mount the tubes on my wiper arms. I had to remove the door and vent panel. Upon testing the wipers they will not go down all the way. Is there an adjustment to make the wiper seat all the way down? thanks
Glass installer may have put the wiper arms on wrong(wouldn't be the first time this has happened). Remove the arms, run the motor and see if it "parks" when you shut it off. If so then reinstall the arms in the proper position on the shafts.
Hi thanks for getting back to me. Isnt there only one way to mount the wipers. I thought there was a keyway on the wiper arms.
Yes there are adjustments, but what do you mean by "mount the tubes on my wiper arms"? Aren't the squirter tubes and wiper arms one assembly, soldered together?
What position is "not go down all of the way"?
If you have the AIM, there is a page in there that explains wiper arm adjustment.
If your wipers are parking nearly all of the way down, there is a slotted bolt adjustment in the rods near the wiper motor transmission. This adjustment allows for the spacing of the arms (I believe drivers side arm should be underneath the passenger side arm when parked.). This adjustment also controls when the passenger side arm makes contact with the vacuum plunger that will close the wiper door.
The AIM picture is worth a thousand words.
Received 2,878 Likes
Hi 2001,
Although doing what you did shouldn't have affected the motor in any way can you tell if the motor is going to 'park' position as d74 suggested.
It's that movement that settles the wiper arms tight against the stop.
Since the blade stop bracket was probably removed to change the windshield did IT get put back on exactly right?
Regards,
Alan
This is where the adjustment that Revi mentioned is made, it's part of what controls the individual arm's movement.
Regards,
Alan
Hi, I have to work tonight but I will look tomorrow night. The wipers are not going down enough or parking low enough for the wiper door to close.
You are aware that you MUST have the correct wiper blades on the arms. They HAVE TO BE really thin...so using the blades for a 1982 will not work...they are too thick.
DUB
DUB
Ok, I figured it out. Yes the adjustment worked. But I bought a bunch of wipers and wiper tubes from what I was told was a 71. I matched up the wipers cleaned and mounted the tubes and installed them.At that point I had the problem. The drivers side is fine but the passenger side gave me all the problems. I took off the passenger side wiper with the new tube installed and matched it up with the old one and it was so close I could barely see a difference if any. I mounted the old wiper on passenger side without the tube and it worked great.So today I mounted the washer tube on the old wiper and I know this will solve the problem. I will post more as I go on. thanks
