Need Advice on Suspension Purchase
I'm thinking of going with a Stage 4 Suspension Kit.
http://www.ecklerscorvette.com/corve...1963-1979.html
Ive compared it to buying each part separately on Summit and seems its hundreds cheaper.
Ive looked elsewhere online for a good suspension kit, but cant find much.
Anyone have suggestions as to a better source for cheaper or better parts for around $800.00 to fit the budget?
Thanks,
Lucas
Thanks,
Lucas
Thanks,
Lucas
Thanks,
Lucas
This in the exact kit that I have been looking at too. Just waiting for my tax refund first.
I'd rather get Bilstein and a monoleaf but my budget has to fit a R&P conversion now too
Before you or anyone starts tossing frog pelts at parts ask yourself how you will use the car, in my case a street cruiser driven in a legal fashion, yeah, I know how lame, but honest, do you "need" that performance set up or just think it would be "cool" lots of others ways to spend money on things you do need,
The stock c3 had state of the art suspension in its day for most people its all they need....
You should take a look at your local parts store....for the most part they will have every thing and brand name parts.......
And without the Corvette tax
t
t
I'm dealing with a neglected family summer car thats been sitting for over 5 years. Body is off and chassis disassembled. Since I have to invest in new parts, why not pitch the extra for more performance based parts? It seemed like a no-brainer in my opinion.
You are right, I will defiantly check out some part stores around the city. But with online shopping being the big thing these days, I would be surprised if a local parts store in the middle of Canada can get a better deal.
Not trying to tell you which way to go, just answering the question of "why not?"
Performance parts are usually more expensive than stock replacement parts. If stock is sufficient for your end use, you're better off saving the money and putting it toward other things you need.
Thank you everyone for your replies though, I am doing this rebuild by myself and need all the help I can get.
If anyone has a decent online supplier for stock corvette parts let me know, currently looking now to see what I can find.
before spending any money try to find some one that has a composite rear spring. I went that way on my 76 330lbs with qa1Qa1 shocks. the rear strut rods I updated at that time to poly mount. What a difference in the car
This year I am changing out the front upper arms to tubular ones, 550 lbs front springs and the rear trailing arms to offset ones.
I don't need the offset arms at this time but at least they will be updated when and if I need them.
yeah it might be overkill for a street car but it will be fun.
I have a mild 350 putting out 426hp @6k and 442ft/lbs @4k very mild mannerd LOL
So many times it's a buyers market for good condition used and pre owned never used parts for sale all over the net....but if a person want to save time looking and just spend...
I am super cheap I will spend hours online to save a buck or two. but then again I am buidling a 69 convertible bb car with vb suspension and lots of mods for less than 13K total so..
No, I didnt need the vb stuff at all, but it was on the donor chassis...
what he said,
very true statement take your time and search for deals they are out there
craigslist is a great resource too ive bought many used parts that are either new or slightly used for great savings
My L-88 hood was like that the seller wanted some huge price and I made my offer twice over about 6 weeks, he took it...
I scored that new in the box 1400.00 value 69 front clip for 400.00 took over a month but it's mine.
Received 1,469 Likes
Cruise-In II Veteran
No sense going aftermarket if rebuilt stock meets your needs.
Great advice, I will put more time into my search and will try to find used parts. If anyone knows of anyone trying to sell the parts from that suspension kit (sway bars, absorbers, coils, leaf spring, strut rods etc.) Let me know
Look in the C3 parts section for some F-41 sway bars (should run around $300 to buy/install ), if you have a Small Block I would run a 15/16" front bar with the rear bar. Since all BB Vettes had front/rear bars, I take it you have a small block. Then buy a set of Bilstein HD or Sport ( stiffer valving on the Sport shocks, think twice about this if you own a roadster .) Bolt on the sway bars and shocks, have fun driving. If you plan on autocrossing some F-41 springs will help, then a Borgeson steering box upgrade. My 72 LT-1 won a autocross title with F-41 hardware and good shocks on it ( 5 point racing harness, Kirkey road race seat and sticky tires made it run similar times to C5 Z06's. ) I don't like KYB shocks at all. You need to search the C3 tech/performance section of the Forum to get a better idea of where you want to go.
From my personal experience, if you do nothing else, go with a composite rear spring. The improvement in ride quality is astounding!!
I bought a Vette Brake Products Street and Strip suspension for my 68. This was 550 lb/inch front suspension coil springs and a stiff rear wheel spring. My 68 Convertible came with a factory weight of 3050 pounds according to the AIM. I reduced the car weight by another 150 pounds easy. The light weight of the car and the stiff springs is way too much for freeway driving. The ride is way too much harsh and causes a lot of body flexing. Unless you really plan on motorcross competition with your car, you should not go for these really stiff suspensions.
