Help me decode this engine stamp
1969 coupe with an L46. VIN matches, but the engine ID code confuses me.
V 1 I 2 5 H W. (To be clear, that is the letter "I" following the number "1")
V=Flint, MI
1 I = ??
2 5 = 25th day
H W = 350ci/350hp, no A/C
V=Flint, MI
1 I = ??
2 5 = 25th day
FYI - my car was built May 18, 1970, but the engine was assembled on March 25, 1970.
Obviously, the block would have to been cast prior to the engine's assembly date. This sounds pretty simple, but I have seen restamped blocks, with casting dates after the assembly date.
Cajun, have same car, can't remember engine code offhand, but a Nov. build. Vin 31xxx you should be close. I'll see if I can get pics tommorow, weather permitting
Received 2,878 Likes
Hi C,
Here's a picture of a pad on which the 'I' stamp was used in place of the '1' stamp.
The picture was posted on the DB as part of the thread about the pad you're looking at.
Regards,
Alan
Regards,
Alan
Received 1,468 Likes
Cruise-In II Veteran
