Door Panel Question
Door Panel Question
In looking at my 69 door panels especially the backing, it looks the same as my old 76 panels. That is the backing ONLY . Was the same backing material and molds use from 69 -76???? Just curious.
r
r
Received 2,878 Likes
Hi r,
The original door panels for your 69 would have molded 'paperboard' backing in a tan color.
Most reproduction door panels are made with black abs plastic.
Because the original vinyl 'skin' tends to crack and split, original panels in excellent condition usually bring pretty serious money!
Regards,
Alan
It could well be that the same backing was used for 69 onward.
Regards,
Alan
Hi r,
Regards,
Alan
Regards,
Alan
Thank you
r
I'm going to guess that the panel fiberboard base was the same from 68-77. I have a pile of old panels, and the base on all of them looks the same.
If you look at the picture that Alan posted, you can see a raised horizontal rectangle near the top center of the panel. This is where the door pull cup is located on 68 panels. The 69-77 panels have that small square cutout at the forward end of the rectangle, which is where the top bolt of the 69 up door pulls bolt on. 68 panels wouldn't need the cutout, but otherwise all 68-77 panel backers appears to be the same.
You may want to check with Al Knoch, as I think they now offer repro panels, with the original style fiberboard base.
Hi,
If you carefully you can see the holes in the paper board for the wood grain panel used in a deluxe interior.
I don't see anything though for mounting the extra piece of carpet and it's trim to the lower part of the panel.
Regards,
Alan
Regards,
Alan
r
Thank You
r
With the [original] fiber panels, you really need to install the water vapor (clear plastic) film or some thin vinyl sheeting with them. Those fiber panels really suck up any water/moisture and then start disintegrating.
Hi r,
The pressboard backing from AK may be a nice possibility for 68-69 cars.
In talking to him about them at Carlisle I asked about the 70-72 panels that I'd be interested in.
He''s using the same vinyl skin regardless of the backing and the reproduction skin he uses lacks some of the detail, especially in the comfort-weave panel detail, that original 70-72 panels have.
So that makes another reproduction that's enticingly close but still not QUITE right.
Regards,
Alan
Regards,
Alan
Hi r,
Regards,
Alan
Regards,
Alan
r
Hi r,
The detail panel is different for your 69 than for 70-72 cars.
I really don't know how accurate the AK vinyl detail is for the 69 panels.
Regards,
Alan
Regards,
Alan
Trust me Roger, if you plan to drive your car a lot, leaning over to crank the passenger window down gets old REAL fast. That is why I added power windows to my coupe. I also never had a car with them and to me this was luxury!
The other thing that I hated is pushing in the stupid seat belt button every time that you start the car, to turn off the red fasten seat belt light. Your finger wears the paint off of the gauge bezel.
I changed that also, on mine. Lou.
door panels
So I just got off the phone with Al Knoch. Nice guy, told me he does make the paperback door panel molds which he said he received from GM years ago. Told me the price and even cut $200 off. I may go that route I'll see. Something to think about anyway. Thank you for all the feedback.
r
r
Seems like there are good and bad to both types of backing material. I'm installing new door panels now with abs and they have more curve than the pressed paper board and it makes it more difficult to pull the bottom in . ( A lot of tension on the panels ) The pressed paper panels flex more and can be pulled in tight without the tension. The only advantage to the abs is that the metal clips that pull the bottom in won't tear the slots when under tension unlike the pressed paper.
Call you soon
r
Seems like there are good and bad to both types of backing material. I The pressed paper panels flex more and can be pulled in tight without the tension. The only advantage to the abs is that the metal clips that pull the bottom in won't tear the slots when under tension unlike the pressed paper.
BTW. My 68 original door panels are just excellent. There is a 1/4 inch crack on one of them!!!! I'm seriously thinking about buying a pair of repro panels just to have them in the future. 10...15 years from now, it may be impossible to buy repro panels.
My original 68 dashboard is like new. My 68 original plastic steering wheel has no cracks. I'm on my second set of seat covers though. No real problems for me with manual windows. The car interior is narrow enough, that I can easily lean over from the driver's seat and roll up the passenger's window. I cleaned up the window interior mechanisms/rollers and it's now so much easier to roll up and down the windows...got rid of the hard caked grease.
r
The pressed fiberboard panels flex and are easier to fit in...my opinion.
r
Can you find an [unobtrusive] plastic hole plug that will close off that window crank hole? You can use matching vinyl dye to have the same interior color. No, it won't be perfect; but the padded panel will be correct and you can have power windows.
Another option (what I would likely do) is to acually fill that hole from the backside with a fiber backing, then fill/blend the surface with a polyester resin. As the resin hardens, you can use a piece of similar vinyl to press into the surface to create the 'grain' look. Finally, recolor the whole thing with matching vinyl dye. Much more trouble, but you end up with what you really want.
