Headlight Assembly Removal
I am at this stage
Vacuum hoses removed, wiring removed, and 3 bolts holding assembly to header bar are out.
In order to get the assembly out it looks like headlight door has to be in the closed position, but I cant get it closed.
How do you get it down?
You can unlock the links by pulling forward on the joint where they come together. Once you do this it will easily close.
John
Those pivot arms are kinda of like a knee joint (well if your knees are still good, ha!), they swing pass the neutral position to sorta of lock. you just push at the hinge point to go past the neutral point and they will swing closed (watch your fingers, too).
Hope this helps.
Hope this helps.
Thanks for the replies....I got the door closed.
I have now removed the 3 bolts holding it to the header bar, and the 2 bolts under the front bumper.
I have the whole unit loose and free now, but can't find a way to remove it. Pulling it back towards the engine it gets stuck on inner fender.
Do I need to disassemble more of it, or is there a trick to working it out as one unit?
Thanks again
Thanks again
Imho...
IMHO, I have not done this job yet on my 72, in my case, I need to reassembly through the holes. But as I understand it, you have to remove and install in pieces, so if it were me, I would take it all apart.
Thanks again
Thanks again
When I did this I took everything apart and did it in pieces. I couldn't find any other way to make it work. Once it is apart you can turn the frame side ways to get it out.
John
I removed the arm on the side..made it close, but I still don't think it can be removed without further dis-assembly.
It does not look like a fun job to take it apart while it is in the car....where did you start?
Zane
Disassembly is relatively simple. Putting it back together so everything looks nice an lines up is much harder. Remove all the springs and links first. Then it is just a matter of removing the headlight door and you should be able to get it out.
John
John
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Thanks again
Thanks again
Remove the three rear bolts on the header and the two up front and the entire headlamp assembly will come out.
Willcox
If we are re-conditioning a headlamp housing, we remove it as a assembly, then take the assembly apart on the bench. If is way easier to take apart this way.
Willcox
Willcox
the only way I got them in or out was through the core support, that means you might have to remove the radiator.
Believe it or not the rad and cradle are out. So is the engine. I just can't find the right path to remove the assembly. Maybe I'll try the driver's side tomorrow. Giving up for tonight.
Got them out. The trick was to remove the center support to allow me to move them inward.
Now on to the header bar removal.
Thanks for all the help!
Former Vendor
I do see a bunch of galvanic corrosion on the back side (the white powder on your support is caused by this) and you'll need to tend to this before you re-install. Clean as much up as possible and when you re-assembly you may have to make a plate for the bottom side to add reinforcement. (look for cracks around the holes). We like to use a thin rubber gasket between the header and the headlamp support when we re-assemble, it keeps down the possibility of further corrosion. (we use the centers from the door handle gaskets for this lol).
