My 1972 Base car restore begins.
#161
5-28-16 update...
Its been awhile now but I have totally reorganized my shop. Too much junk in the way. I built a mezzanine and stored all corvette parts, ducati parts, Porsche parts, vespa parts, triumph parts, fiat parts.....gees. All the heavy stuff in on the floor level. I moved the lift to the corner as I think it will be better there. As having to walk around and under it when it was just inside door. Anyway...I think all I have now is to organize the peg board and I am back to sanding a car.
#162
5-28-16 update...
Have you thought about fabricating a temporary sanding booth to help contain the dust?
#164
#165
Hi Roger...this is a 50 x 50 with a 14 EH. A 30 x 40 would be great if you don't have all the junk I have to store along with car and bike stuff. I think also you could get by with a 12'-0 eh if you are planning a lift.
#166
Thanks for that. Your place looks great.
RVZIO
#167
Roger...It is amazing how fast a large shop gets full. With a lift you will need "room to move around. Go as big as you can. 2 things that CAN NOT be too big. One is a shop and another is a TV. If its too tight then you will kick yourself...too big and well...you will not notice in a good way.
#168
6-5-16 update...
After pricing all new air conditioning parts I decided to go with VintageAir. Ordered the SureFit for 68 to 72 corvette small block. Mounted the new compressor today with all new brackets from Vintage Air. So far I am impressed. The belt alignment is spot on. Hope to get some more sanding done next weekend but not sure. Super Bike racing at Barber in Birmingham. I will see which wins out.
#169
Ac
Hi Dean, that AC unit looks pretty slick and should keep your cabin real cool. Very nice. I have been going back to your shop picture almost daily to see various things. Can't wait to get mine. Oh, one garage door centered???
RVZIO
RVZIO
#170
Thanks Roger. My shop is a industrial area rental. I will build my own after my move as well. I am here helping with sick parents right now.
I have been a metal building draftsman for 38 years. I would recommend doors centered only in the end wall ( gabled wall ) . For design purposes the sidewalls are more important for bracing reasons. Also moving cars around I think. Metal building start to be cost effective at 35 plus feet wide. Narrower and wood might be cheaper. I will go metal myself. 50 wide allows you to park cars along each sidewall without crowding and leaving a gap to drive thru.
I would be happy to help you with your new garage...put you in contact with a good builder. Where your moving is obviously a coastal area so their codes are heavier as regards wind and uplift....no snow though which helps. Anyway...I would be happy to help in the design.
Mine, right now, has one 10 wide by 14 high overhead door.....It enough but if you go bigger you might want to think about 2 doors....one in each end wall for "drive thru". I am single and plan to have a garage big enough for 6 cars and 6 motorcycles.....I plan to wall a corner and live in it....no house.
#171
My career took me on a different path into the automotive industry where I'm now working as a process engineer at Nissan.
Once the spousal unit and I have an empty nest, I'm planning to downsize the house and upsize the shop.
#173
RVZIO
#174
I will look and get back to you. You may want to price a 60 long as that could be 3 bays at 20. A 2 bay building from a design standpoint is expensive. Try to work with at least 3 bays to get your best bang for your dollar.
#175
Allied Steel appears to be a broker. They are a middle man ( nothing wrong with that ) and buy a building from a manufacturer and resells to the public.
Try "American buildings Company" out of Eufaula, Alabama. They will have a dealer in your area that can give you a price and handle the deal. They are a major manufacturer and not that far from your new home. Freight will be an issue if you buy from some.
http://www.americanbuildings.com/Loc...etail?md_id=SP
#178
Not much has been worked on. New parts are piling up so that is good. Talked to DUB on the phone a few days ago and will be sending mine to him to finish. I will need to paint motor bay Hot rod black so the body will go back on frame...maybe for the last time.
In the meanwhile I picked up a 1970 that is drivable now...I am sure it will help as a reference car when the 72 goes back together...That's what I am telling myself.
Nothing special on the 70...base motor with auto. Main numbers match. May do a restore on that one when the 72 is finished. I think I have a vette problem
#179
Your thread is an inspiration. I am in the planning, acquiring information and parts stage now.
If you don't mind me asking, what did dipping the frame cost? This is the closest place, to Dallas/Fort Worth, to dip the frame I have heard of.
Jim
Jim
