78 4 speed
would be easier if you posted pictures of the car here covering engine, underside of the car, etc. Otherwise you have to determine things like how much is original to the car, original engine, transmission etc and be able to confirm that they are. Check for frame rust and damage. Does everything work, climate control, headlights, radio, etc. Body damage was there an accident in the cars history and how well was it repaired. You should try and find a local Corvette club who has someone willing to go with you.
https://www.corvetteforum.com/forums...-corvette.html
Take pictures of or document what is on the Trim Tag, VIN, and Engine Stamp Pad.
If you are looking for some info/numbers:
http://www.corvetteactioncenter.com/...1978/78id.html
http://www.corvetteactioncenter.com/...78/78prod.html
They produced about 8000 4spd of which 3385 were close ratio.
good luck.
good luck.
Thank you
good luck.
Thank you
good luck.
The difference: Parts!
I have a '78 L82 with a close ratio super T10 4 spd. Very fun car. It was running and driving when I bought it for $8,000. I put 3,000 mi. on it last summer and had a ball. I have since repaired the frame, rebuilt the suspension and rear end, replaced the brake system, and multiple other projects. I'm currently finishing stripping all the paint off and will be pulling the motor to be rebuilt to 400hp/400 ft.lbs. when it goes to get painted later this month. I currently have $27K in it (not counting my labor) and will have about $35,000 when finished. I'm guessing resale value would be about $15,000 so it's NOT an investment. However, I've totally enjoyed the process and it should be stone cold reliable when I'm finished. I plan to drive it until I'm too old to use the clutch and then give it to one of the grand kids who seems interested. The '78 is a really fine choice--easily "rodded" to get better than earlier shark performance w/out the initial purchase cost. The fastback styling allows enough luggage room for my wife and I to take week long trips. I will warn you though, you will get LOTS of people wanting to stop and talk to you about your car
L48
it is L48. Has repaint ,correct color. Not a bad repaint. Solid frame/cage. Interior needs minor work. Weak HP, 85k untouched motor. See how owner feels in week or so if not sold. Thanks for all's help.
nice
