Fiberglass bonding...
Just had my 76 soda blasted and ordered a set of L88 rear fender flares from Mid America to add some extra meat. Need to get some input on what the best adhesive would be to join the flares to the fiberglass body. Plan to reinforce with fiberglass mat underside but also need suggestions on what product would be the best filler for the topside in prep for primer and paint. I have been looking at the Evercoat Rage Extreme 120 but can find no info on fiberglass application. I have also been looking at the Duraglas Short Strand but am unsure of the finishing characteristics of this product. Whatever I use will have to be easily sandable for contour and have minimal shrinkage quality. Suggestions please....
1969/1971/1976 Coupes
Do a search for SUPRJAMES. Here is a link for his flare application but doesnt go into detail of what he used (i don't think). I haven't seen him on here for a while but maybe he lurks and will respond to a PM. He did a super job installing them. One of my faves on this site!!!
Terry
https://www.corvetteforum.com/forums...-finished.html
Terry
Received 1,468 Likes
Cruise-In II Veteran
Your 76 is SMC. What are your flares made of?
Here's some good info on SMC...
http://www.superchevy.com/how-to/vem...ody-materials/
Make sure you use the right resin for SMC when bonding the panels.
Later,
Lee
Later,
Lee
I like Fusor products . They make good quality products for bonding all types of fiberglass including fiberglass to fiberglass and fiberglass to metal.
Thanks for the responses, got my flares from Mid America yesterday and found some more good info. The flares are made to be rivited in place so I have decided to go with fiberglass mat top and bottom using Tigerhair for the rough in. The final finish will be with Rage Ultra. Both products work with regular fiberglass and SMC. Nice looking flares but not much to them for $350....law of supply and demand I guess...thanks again.
You know I did notice that on the front of my vette but wasn't sure what it was....thank you
Honestly....I would not even rivet them on. I have numerous clamps that would allow me to correctly position the flare and bond it on with an adhesive that does not require any gun to apply. The reason for this is that you will be dealing with a seam that you will laminate over or fill over. And using a 2 part epoxy....even though it works...it can cause the seam to shop up later when under direct sunlight. These new epoxy adhesives are mainly used UNDER a panel where there is NO exposed seam to contend with.
Can you rivet it on...or go buy really small screws and screw it on while bonding it in place....YES YOU CAN.....but the 'trick' is where you drill and screw the panels on...so you are not fighting with holes that you need to fill CORRECTLY and not have them come back on you later.
If you have already purchased the products you mentioned...OH WELL...because there are other products that I can confirm and SWEAR BY that will out perform what you mentioned.
If you are doing this...and riveting on the panel and bonding on ....just make sure you drill out the rivets when completed.
You are aware there is a 'PAINT and BODY' section here on the forum.
Hope all goes well in your project....because I have done this and other add on's many times over. Just trying to offer advice.
DUB
DUB
