Fuel tank size
Fuel tank size
I need to replace the fuel tank on my '69. My car has a build date of Dec. 1969 making it one of the last '69 built. The book says that they hold 20 gallons but, my tank has the long indention on the side so it looks like the tank used on the 1970 model that holds 24 gallons. has anyone else run into this?
Received 2,878 Likes
Hi h,
I believe all original tanks installed from 68-72 were the same basic tank with just changes in the number and placement of nipples for the return line and vapor control line if used.
20 gal. capacity for all as Revi said.
Regards,
Alan
Regards,
Alan
You need this one http://www.gastanks.com/Aug-1969-70-...ctinfo/GM-33E/
