Questions about Putting a Modern LS7 in a '69
I have seen it delt with a few different ways. by removing the ends and threading the holes and putting 90 deg elbows. I'm working on making a plate that will bolt onto where the inlets are now and redirects it to the rear where I will connect the hoses.
The heater hose fittings can be removed by rocking them while pulling.
The holes are perfect size for NPT taps (3/8 & 1/2" IIRC). Then just get some right angle adapters from Summit, Sears hardware, etc.
I've got the Kwik compressor bracket and seen the Holley installed. Get the holley.
Hey Gary,
Where did you get your engine mounts and adapters from? What offset did you use?
What oil pan did you use?
How did you set up your fuel pump?
What did you do for air intakes?
I went to VIR for the first time today in my 01. Wow! Can't wait to do it in my 69! My 69 will be around 600HP at the flywheel with a good intake, stepped headers, and a tune.
-Adam
-Adam
So pretty! Thanks for the pic! Can't wait to mate mine!
Location: Carolina raised but in Loveland CO for tha duration
T-56 in 68
I had minimal problems putting a T-56 in my 68. The forward U-joint hit, requiring a bit of trimming. Had to fabricate a cross member, of course. My biggest problem has been getting the 68 chassis to handle 544 hp without requiring a change of underwear (400 ci Dart block, Accel DFI fi (mistake), AFR heads).
Jerre
Jerre
I tried the 1" setbacks, but the 621 bell was rattling against the tunnel of the sagging body. I ended up with this type and solid motor mounts.
http://www.ebay.com/itm/Stock-Location-Engine-Motor-Mount-Adapter-Plates-for-LSx-LS1-LS2-LS7-Swap-/181672886469?hash=item2a4c8c40c5&vxp=mtr
I'm running an 02 Z06 vette batwing pan.
Fuel pup (Walbro external 255 inline) and vet fuel filter/regulator are mounted inside the rear passenger side frame rail.
I swapped the LQ9 truck intake for an LS1. For the intake tubing, I made a filter housing that sits on top of the intake.
No where else to go on mine.
QUOTE=Young69Owner;1589340505]Hey Gary,
-Adam[/QUOTE]
-Adam[/QUOTE]
