front coil springs
front coil springs
I ordered front coil springs from Ecklers stock # A6998 grand touring springs for small block,after i removed old springs from my 74 , the new ones are two coils shorter than the old ones, does this mean that the front end will be even lower than it already is? If it is Ill return them, what should i order to have original height?
Your ride height will actually end up higher until the springs work themselves in after time! They are shorter to make installation easier, but, the spring rate is higher; the ride height ends up being stock once the weight is on them.
I have the same springs in a small block and the rate and height are perfect for me.
Unfortunately, trimming springs to get the correct ride height with repro springs may be necessary. My ZZ4 engine with aluminum parts was much lighter than the stock 68 engine. I installed a VBP performance suspension, and I did the initial install of the coil springs. The nose stuck up in the air due to the extra light weight. Paid Guildstrand Motor sports to cut the front springs down. Happy to pay someone to do this for me!!!
