68-77 Sill plates. Is there a left side and a right side?
Do the 68 thru 77 sill plates have a left sill plate and a right sill plate? Or will one side fit the other side? Thanks, Tom.
the vendors sell them as single pieces as opposed to pairs and there is no right or left
Thanks guys. I thought as much! The reason I ask is I have both my 68 and 82 vetts parked next to each other in the garage and can only open my 68's driver side door so I couldn't compare one side to the other !! Thanks, Tom.
Received 2,878 Likes
Hi n2m,
I'm not sure what you saw that made you think there were left and right plates, but the AIM only lists a single part number which generally means there's no right or left.
There is an inside and outside edge though.
Regards,
Alan
Regards,
Alan
Received 1,469 Likes
Cruise-In II Veteran
I used aluminum trim from the local hardware store. Cut to length with a grinder, scuffed'em and sprayed satin black. Looks better than my thin 80 originals and costs 10 bucks
