View Poll Results: Start A Body Off Restoration Thread?
Voters: 65. You may not vote on this poll
Body Off Thread.........Yes/No?
I’m going to be doing a body off restoration on a 75’ Coupe that has been sitting in my garage for 26 years and since I see several body off resto’s in the past as well as on going would there be any interest in me starting a new thread of my own so I can get advice as well as help other in the future?
In reality I started repairing the car about 10 years ago but didn’t get too far so I decided last year that I wasn’t going to be happy unless I did a body off. If there are enough people showing interest, than I’ll start a thread come summer?
I know some will say, why not, but I’ll only start one if it’s of real value, otherwise I’ll probably just start threads when I run into problems.
I have a soft spot for '75s and enjoy the finds, progress, trials and tribulations of body off threads. Can you tell us any more about the car? Colors, options, type of restoration? I tend to follow more of the factory correct threads.
Absolutely Pete;
I'm the original owner, of the Blue 75' Coupe with silver leather deluxe interior, with other options such as power windows, tilt telescopic, rear window defogger, Auto 400 trans, am/fm stereo, map light, dual horns, 308 diff gears. I don't have a/c but will add vintage a/c to the build.
I'm located in Brampton, Ontario, Canada and the car has around 56k original miles. My budget will be between 30-35k including paint and time frame will be less than one year.
The only work I won't do is the paint.
Absolutely Pete;
Good luck in your poll and decision
r
Finalist 2021 C3 of the Year - Modified
Absolutely Pete;
Nam Labrat
Received 4,173 Likes
FYI............I'm doing a "reverse restomod"....that way I can drive my first and only Vette while I'm doing the repairs on the car and budget my money monthly. When the time comes I will lift the body/repair & paint the frame/bolt the body back onto the frame and go on a month roadtrip!
It sounds like you have the plan AND the funds to stick with it.
Go for it!
Go for it!
i say do it if you want to....every car and every rebuild is unique, and there are things people will learn from you taking the time to chronicle your journey...good luck!
Here is mine, and I'm just about finished...need to do an update.
https://www.corvetteforum.com/forums...-any-tips.html
Just to be clear, this thread isn't about whether to do the resto or not, it's about whether to start a thread about it or not. If I get less then a 60% "absolutely" then there is not need to.
Thanks for the replies everyone.
"taking some time to take pictures and post on a regular basis which will take away from the build".
I believe the opposite, A picture history of your build is beneficial to you, the next owner, and other members on here.
As far as the time, really how long does it take, to take the pictures and post?
Feedback, and questions from fellow members will keep you directed and motivated.
You can't work on it 24/7, taking time away from the actual build allows you to regroup/focus, and possibly to notice something you may have over looked.
I will follow along if you do a build thread.
Good luck on your build, whether we can witness it, or not.
Received 2,878 Likes
Hi M,
While the restoration threads are interesting to read and sometimes valuable for their information I think the greater benefit is for the restorer.
The taking of pictures and posting of information forces the person to step back and to a look at what he has going on.
I believe a successful restoration or resto-modification requires several things.
First, a PLAN….. what will the result be.
Second, SEQUENCE….there needs to be a schedule, not of time, but of the order in which things will be done.
Third, MOMENTUM…. things will not move at a steady pace and don't need to, but even tiny steps are continuing to be made.
Fourth, QUALITY CONTROL…..what will be acceptable and what won't.
There are and have been threads that demonstrate all of these things and threads that demonstrate none of them.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
Hi M,
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
r
tokim
Reading your comments put it in a different perspective and I now feel it's wasn't fair for me to make those comments therefore I'll delete it. I guess I wasn't looking at it clearly.
Alan 71
Thank you, and you're correct.
rvzio
Thanks for starting your resto thread as it will help me.
Alan 71
rvzio
Received 1,468 Likes
Cruise-In II Veteran
FWIW: restoration threads tend to get drawn out and lengthy. Folks can lose interest in large threads.
Cruise-In IX Veteran
The biggest things you will need are Money and Time. I have been into my resto since 2006. For the first few years money was always my issue. I have to rebuild and replace a lot of parts and it costs a lot. Now that I finally have money to spend, I find time hard to find.
The thing to remember is "one bolt at a time".
I have a REALLY good understanding of why/how someone can lose interest in a project. As with a kit car, there isn't really an assembly manual where you can count your progress one page at a time. After a bunch of stuff is apart, you start to think to yourself "WOW...what the hell do I do now?"
This started happening to me when I replaced my engine and refreshed the under-hood wiring. Prepping the wires and the engine bay seemed to take FOREVER. And even after the engine was in, there were SOOOOO many little things to take care of. It seemed hopeless, even on a project that 'small'. One bolt at a time, and one hour at a time. It was easy once I saw the light at the end of the tunnel.
I'm reassembling the entire rear end of my car now. It's been out for about 2 months. There's ALWAYS one more thing to do. One more line to replace. One more bolt to tighten. One more thing to paint. Last night, I FINALLY got around to stripping/prepping my gas tank...45 years of gunk and goo...2+ constant hours with a wire wheel. I Finally have it done, though, and it feels GREAT. It's just a matter of bolting things together and sitting the car down. Felt like a BIG mountain not that long ago, but one bolt at a time...and I can see that glimmer of light.
If I was being 100% honest, I would try to DISCOURAGE you from taking the entire car apart at once. That's my feeling, though, knowing how many of these projects end up being passed along in boxes.
Good luck on whatever your decision is. I'm sure it will be the right choice for you.
try to understand what your definition of 'body off restoration' is. there is great disparity in each person's definition. are you talking every nut and bolt restoration? do you require exact paint finishes? the nickel and dime stuff will turn into thousands of $$. are you rebuilding to exact factory look alike?
some people pay big bucks for that exact air cleaner wing nut whereas others buy the entire air cleaner from autozone.
prepare to spend 25% of your time shopping, researching.. ebay etc...
prepare for bad parts, very expensive parts, shoddy work from services that you might contract out.
watch out for the time away from your friends and family and what it does to your relationships.. got Kids in soccer? prepare for that to take priority.
got a budget? prepare to add 50% to it.
got a 3 car garage? you will need it all.
for a 75, be prepared to be massively upside down financially on your project. you may say it doesn't matter, but it will eat at you the entire project.
rusty frame or a bad bird cage? add months and many $$ to your project.
all these issues and more caused me to stop with my restoration.. sold it all off and bought one mostly done. it only needed about a 100 hours to make it the way I wanted it.
My 75 started as a simple add engine and tranny, do some interior work paint and body work and enjoy the drive...that was 4 years ago, now mucho dollars later the body is still off the frame and every part underneath is changed out. Brake and fuel lines were rusted through, trailing arms rebuilt, front and rear end all rebuilt, my fingerprints are on every part of that car. It was however a great learning experience...is it going to be worth it? Financially NO ! self fulling He** Yes! Since you have owned it for so long it must be part of the family, keep records and post pics every so often , Enjoy the Adventure!
Interesting question, a "should you do it" but this time it's not about some mod that some will say it's your car go for it and a few will diss it just because it's a mod but rather this time the inquiry is should you post a build thread,
I read through the replies the positive ones have so much merit where the less than encouraging replies are pretty lame reasons not to post your build.
Start with this is YOUR build, do you feel like taking the extra time to jot down what is going on and include pictures lots of pictures and letting people into your world?
Can you blow off pointless replies made that just want to be negative? ( you know the ones that live for that )
Personally since every c3 even of the same year is different, had different history and so on I find something interesting in every build posted on here, look at doors build, it's goes into fellows talking like they would at a cruise and I love it...
I posted my build thread which is rather stagnant right now due to my car still at the shop I posted that build thread for me and for others to get ideas how to do things and how not to do things,
If a person gets bored in any thread they simply do not have to read it...move on to something they do have interest in.
In my way of thinking posting your build is just what a forum like this is made for.
I have put money aside for this project and I figure it will take approximately 800 hours from start to finish. Since I started already, I can cut the hours down somewhat. I also intend on doing this full time during the summer.
I feel my budget of $30,000.00 for parts is reasonable, if more are needed then I'll deal with it in the end. The fact that it's been sitting for 26 years has added much to the budget.
I've excepted the fact that it would have been better financially to purchase one in better shape, but this isn't about resale valve, it's about my forum name, which is keeping the dream alive.
My 75 started as a simple add engine and tranny, do some interior work paint and body work and enjoy the drive...that was 4 years ago, now mucho dollars later the body is still off the frame and every part underneath is changed out. Financially NO ! self fulling He** Yes! Since you have owned it for so long it must be part of the family, keep records and post pics every so often , Enjoy the Adventure!
The only saving grace financially is my labour will be free.
