how much time
how much time
1976 front end rebuild. Are there any opinions as to approximately how many hours to R&R the whole front suspension?
Upper and lower control arms, springs, inner and outer tie rod ends, sway bar, steering arm....what else?
I already have done the power steering pieces. Any estimates appreciated.
A lot depends on your skill level the tools you have and if you have a lift. I have done this many times so I can do it in hours. Most first or 2nd timers will take days. To many variables to put down a specific time.
Fist time or 50th it never stops trying hard to kick your butt, each time finds a new way to inflict pain, it's a dirty nasty job,
I can do it in a long day ( or two ) , but takes me several days to recover...lol
better than I thought
Well, things sound better than I had anticipated. It will be in my friends shop. We will have all the tools and press etc. He is a very experienced mechanic, worked on several Corvettes.
I was thinking about 40 hours so I'm VERY happy to hear we might do it in 16-20 hrs.
Nam Labrat
Received 4,173 Likes
Cleaning and painting all the parts takes about 50% of the total time.....IF you have all the replacement parts in a big box on the work bench!
There's a very good thread about using a metal-cutting hole saw to remove the old control arm bushings that will save you lots of time and burned fingers! I think I posted some pics in my thread....yep............pg. 15-17
Chasing down parts at auto stores allover town can add another half-day.......like when you discover that the spindle nut has some well-worn threads and you've misplaced the bolts for the lower shock-mounts
Received 1,468 Likes
Cruise-In II Veteran
Put it up on a lift or jacks and steam clean or pressure wash BEFORE you take this one. Not having to work on it, with pounds of crud removed make it a much better experience. And if you want to make it faster, bag and tag all the fasteners as you remove them. This helps in a quick reassembly, like when the sway bar nuts, bolts and washers are right there in your hands, as you reassemble it, ditto for the shock bolts and brake calipers.
Greg... careful with that "while it's apart" thinking or the next thing you know you'll be two years into it and wondering if you're EVER going to see it with the body on it again!
While I'm in there...
Oh man! I know that one well! I've got a 1980 Camaro that went from "just the control arm bushings" to a complete restoration.
If your friend has a garage with tools, a complete front end rebuild kit should be all u need. Nothing too magical on the corvette, but I would recommend a service manual for your yr car. They give u all the torque specs and reading the directions isn't always a bad thing to do.
I would probably allow a full day for the job, providing u don't get too **** on cleaning and re painting.
Nam Labrat
What did I forget?
manual AIM
I have an AIM for a 72. I haven't been able to find for a '76.
Thanks for all the feed back. I bought all my parts from Duntov Corvette.
Get a 74 Service manual and 76 Supplement while you're at it.
See this thread for a bigger list of books to buy.
