need help identifing some wires
Old 04-14-2015, 08:47 AM
bertmac1111
bertmac1111's Avatar
Default need help identifing some wires
In the attached pic I need some help ID'ing some of these wires.
These are all engine wiring harness
from left to right
white wire and blue wire
yellow wire and Blue wire
orange
green wire and tan wire
tan wire
orange wire and white wire
Any help will is appreciated..
Bert
Old 04-14-2015, 10:23 AM
bertmac1111
Guess I should have added...its a 1973 454 auto car...
thanks
Old 04-14-2015, 11:03 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Bert,
The 2 to the left of center (blue and yellow with the tubular connectors) are pretty easy!
Regards,
Alan
Through the black plastic cover for the washer pump.
Old 04-14-2015, 01:17 PM
bertmac1111
Thanks Alan, I figured out right after I posted that the 2 on the far left are the anti-theft switch for the hood..you ID'd the next two..still need some help on others.. I think the orange is oil pressure but according to drawings it should be blue
Old 04-14-2015, 06:40 PM
bertmac1111
Alan, in the bottom right corner of your second picture there is a relay. What is that relay for? And what color are the wires going to it? there isn't one on this car.
Bert
Old 04-14-2015, 08:26 PM
Alan 71
Alan 71's Avatar
Hi Bert,
There are 2 relays mounted on that small bracket.
In 71 the engines had an emission control system called Combined Emission Control (CEC).
Those relays are part of the system and control a vacuum/electric solenoid on the carburetor that increases idle speed at certain engine operating temperatures and in other situations.
One is a 'reversing relay' and the other is a 'delay timer'.
I don't know whether your 73 has something similar that those wires may be connectors for.
Sorry I can't be of more help!
Regards,
Alan
Old 04-14-2015, 08:29 PM
bertmac1111
that helps Alan, Thanks
Old 04-14-2015, 09:03 PM
76vette1
76vette1's Avatar
The location of the wire, color and the connector says blower motor to me and my 74 manual.
Old 04-14-2015, 09:38 PM
bertmac1111
76vette1,
Your reply made me think about something..the plug size on the orange wire is too big to be the fan. I just went out and looked and it is the plug on the side of the Trannsmission. the TCS switch. In this picture the purple is the fan motor feed with a/c, the small orange would be used on non-A/C cars and the larger orange plug matchs the TCS switch with size and offset of the plug.
Thanks for the input it made me snap that the plugs were different sizes.
Old 04-14-2015, 10:02 PM
bertmac1111
Well, we have eliminated all but these two. any ideas??
Old 04-15-2015, 08:01 AM
Tom73
Tom73's Avatar
Not sure about the color but those clips on the white wire looks like the ones that clip to the valve cover holding the wire to the idle solenoid.
Old 04-15-2015, 09:06 PM
76vette1
76vette1's Avatar
The dbl orange/dbl tan is the trans kickdown switch per the manual.
I checked the "options" schematic and the blower wire changed from orange to purple.
Old 04-15-2015, 09:09 PM
76vette1
76vette1's Avatar
I agree. Idle stop solenoid.
Old 04-15-2015, 09:11 PM
76vette1
76vette1's Avatar
The last one may be the vacuum advance solenoid.
Old 04-15-2015, 10:43 PM
bertmac1111
Thanks for the help everyone..
To need help identifing some wires
Quick Reply: need help identifing some wires
