Is My Recently Purchased C3 an LS6?
#41
Illustrating the fact that a non-numbers matching, but date correct LS6 engine is a hurdle that can be overcome.
Here's where to look for the TI.
Or there may just be holes where it used to be.
#46
So in summary here is where we are:
2 fuel lines running the length of the car
6500 rpm redline tach
Caps not U-bolts on the diff.
No sign of a pulse amplifier
No Big Block hood.
Birthday is April 20th, 1971
No Big Block hood.
#47
2 fuel lines running the length of the car (non-LT1 car)
6500 rpm redline tach (LS6 but can be painfully changed)
Caps not U-bolts on the diff. (Big block - already ruled out LT1 above)
No sign of a pulse amplifier (bad news)
No Big Block hood. (non-indicator - easily changed)
Birthday is April 20th, 1971 (correct date range for LS6)
Perhaps the front end was wrecked and the hood+wheel well replaced?
Would also explain missing ignition decal at fire wall.
Check then for the TI wiring harness (see #4 in above LS6 AIM sheet).
#49
Can you post a pic of the radiator?
#52
and my silver was 44 back on 4-2-15, at work now and don't have the VIN with me......sorry!
three of us in April, must have been a good time for LS6's getting built back in 71.
I have now had it for the last 23 years.
Dean Nelson
Dean Nelson
#56
Looks like the stock big block radiator.
The fan shroud and fan came from another planet.
Can't make out anything from the wire/harness photo.
If it's in there you should be able to see the TI plug just forward of the radiator.
#57
Wow, so you have the optional coon-cooler - definitely a LS6 only option.
Are there LS6 specific details that are cooling related. Like aluminum expansion tank, radiator material, etc.?
#58
