Picked up a 72'
Dr. Detroit
Received 3,891 Likes
Last batch......
More updates soon.......
Jebby
Jebby
Jebbysan (09-29-2015)
Dr. Detroit
Dr. Detroit
Got the Hurst shifter in FINALLY......
Buttoned up some other items.....
I have to port match the Team G and clean up the throat/plenum area.
Getting closer.....
Jebby
Getting closer.....
Jebby
Dr. Detroit
Thank You.....
I just want to add that the McCleod clutch feels awesome with the new rods.....has just the right modulation and not too heavy.
This clutch and shifter are going to be a lot of fun.
Jebby
Jebby
Dr. Detroit
Anticipating start-up on Thanksgiving weekend....
I will post video of it running......it should sound VERY healthy...
A list of mods:
VBP Monoleaf front suspension and steering links.
Carrera shocks all around.
VBP Monoleaf rear and links.
Hurst Competition Shifter
Vintage Hedman long tubes re-ceramic coated
ADDCO Front Sway Bar
New stainless brake lines throughout.
17x8/18x9 American Torq Thrust on 245/45/17-275/40/18 Nitto NT555's
Sony X-Plod DIN stereo with DIN bezel....4x6 Alpine plates in front...6x9 rears in window storage deck.
Smaller wood steering wheel.
406 SBC built by me..Dart 200 Platinums,Team G, Avanti 750HP Holley, 10.5 to 1, Comp 292H Magnum cam.
CSR starter.
McCleod Dual Friction clutch.
Electronic Tach Conversion.
If anyone has any questions...please feel free to ask.....
Jebby
A list of mods:
CSR starter.
Jebby
How are you doing the tach conversion.? I need to do the same for my '69/LS3 at some point. I have a later C3 tach and the Zip kit on the self but haven't decided which to go with.
Dr. Detroit
Jebby
#33
Dr. Detroit
Interior is a 9-10.....it will be Black and Saddle together.
Saddle dash and seats....everything else black.....sorta like Crocketts Ferrari/Vette
It had a few problems.....but I sorted it out.
The goal is EVERYTHING has to work.....including the A/C......
Should be a well rounded, kick *** road burner....
Jebby
#37
Congrats! Looking great! Trust mine turns out that good but it is a long way off! I am putting in a Mr. Gasket (Hurst Ramrod) shifter in mine. Was your switchover to the Comp + very difficult?
#38
Dr. Detroit
I really need the shifter as it has stops. I tend to be a little harsh while banging gears.
Jebby
#39
Dr. Detroit
Hello forum......I have yet to start this as ever body and everything seems to distract me for days turning into weeks.....
Not much of an update....but enough for a bump....besides, we like pictures, right?
Got a New Rebuilt P/S pump and installed my powdercoated pulley.
I installed a factory LT-1 pump....but thinking about it makes me think it is not going to be enough.....soooo.....I had a 110gph/8psi Brand X pump from a previous build kicking around......it is going on as well as a Reg/Bracket/Line setup at the carb (see photo).......if it needs more, I will go electric...but I hate to....
Close ups of some of my powder coated pieces.....I tried like hell to make every fastener under the hood ARP but this proved futile.....more of a PITA than I expected.....I will swap them out later....my Street Rod mentality is slowing me down......
Anyhoo.....I have been fighting a low running virus that is floating around Texas and it has been with me for two weeks......
Going to mount the pump today and work on other things.....
Jebby
Jebby
#40
Dr. Detroit
Pump in.....checked alignment and it is slightly off.....
The only way I see to straighten it is to elongate the hole that the secondary bracket has at the motor mount.....?????
Even then....the Primary cradle sits flat on the block face.....
Hmmmmm......
Anyone want to chime in?
Any ideas are always appreciated.....
Jebby
Hmmmmm......
Jebby
