EFE check valve
EFE check valve
Hello All,
78, the black and white efe check valve is sticking. This is the check valve which is between the efe and the carb. The AIM says the black side must be towards the carb. I've tried Rock auto, Corvette central, Corvette America, nothing. Where can I get it? I may not be using the correct terminology when searching, but I am having no luck. I can post a pic, but I am pretty sure my description should be enough.
Thanks in advance
Bill
Thanks in advance
Bill
The EFE connects to the Thermostatic Vacuum Control Valve, I do not see a check valve.
http://willcoxcorvette.com/product_i...e939b0cec71a0b
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hello All,
Thanks in advance
Bill
Thanks in advance
Bill
I just had one break in my shop and used this part number. Standard Products, PVS71, or other part numbers could be 21214, 212239, 212244, 3031385, 3225912, 7P1000... it is white and has a different temperature range but it should work fine (as long as you are searching for the one that is 3/8 npt.
Willcox
