1969 Corvette Heater Hose Routing & installing shut off valve
I have had the car for about a month now and after reading many threads about the heat in the cabin and after experiencing it on a nice warm day Saturday. I have decided to install a shutoff valve inline from the manifold intake to the heater core. After further inspection (before buying the shut off valve) I noticed the manifold intake hose goes to the upper heater core fitting and the water pump hose goes to the lower heater core fitting.
According to the manuals this is reversed? Is this true?
I do have a 1981 Corvette motor in the car but I think it is still the same. Maybe a different heater core? The heater works fine even if the hoses are reversed?
Also I thought the hoses were different diameters inside going to the heater core?
I assume it is just a loop. Should I reverse back to the way the manual shows, you know what they say - if its not broke don't mess with it.
Not sure if this can cause damage the way it is - or did the person before me do it for a reason or just mixed them up?
Also if I leave it the way it is will the shut off be on the wrong hose?
After all that it may not matter at all Just checking with the experts
In your case you are just looking to stop the flow so it won't matter. Some put a shut offs on both hoses to keep the hot water from even getting to the heater core. One is pretty effective though.
Received 2,878 Likes
Hi 5969,
Originally in 69 there were 2 different size heater hoses.
A 3/4" hose ran from the water pump to the upper pipe on the heater core.
A 5/8" hose ran from the intake manifold to the lower pipe on the heater core.
I guess you should check to see what core is presently installed in your car, and the size of the pipes.
Regards,
Alan
Regards,
Alan
Both outside diameters appear to be the same. Not sure about interior diameter yet. I am always leary removing the old hoses from the core fittings since they can be difficult to get off. If the interior diameter is the same then I could simply switch the hoses - sounds too easy. If I am able to switch which line would you put the cut off on? I have heard it does and doesn't matter - not sure
Nam Labrat
Received 4,153 Likes
Thanks and I will work on it tomorrow - maybe they will both be the same I.D. and I can just switch the hoses at the core. The hose off the intake has a pre-molded 90 deg elbow so I can't switch at manifold and pump.
Also does it matter which hose has the shutoff?
You're asking for trouble messing with the hose ends on the heater core.
If you don't have to don't remove the hose at that point.
That core is fragile and hoses have a way of getting fused onto pipes over time which could require some force to remove them. Cutting them would be the best if it has to be done as doorgunner suggested.
Just cut a hose and insert the valve wherever it's convenient and reachable to actuate the valve.
I agree and hate removing those hoses to switch sides. What if I just leave them as is and put in the shut off? The heat seems to be working fine.
I use this
On the 3/4 line that runs from the manifold to the heater box.
Viega 46044 PureFlow Zero Lead PEX Crimp Ball Valve with 3/4-Inch by 3/4-Inch Crimp x Crimp - Pipe Fittings - Amazon.com
I went to a home improvement store and used this kind of valve.
https://www.menards.com/main/plumbin...653-c-9425.htm
I use this
This valve is much smaller than what most use and is easier to hide out of the way. But it does cost about 3 times what the bigger valve costs.
I use this
Received 1,244 Likes
Yes the water just goes in a loop.
You have a non air conditioned car so you do not need molded hoses at the heater core.
The hoses are two different sizes so you can not just switch them at the core.
Also there is a very good chance of the connector at the heater core breaking so leave them alone.
Whoever installed the 81 engine put the hose adapters at the manifold and water pump in the wrong holes.
Yes! One ball valve is enough.
