1974 convertible 454 rebuild
here is a 1974 convertible 454 4 speed, that is in need of a complete rebuild.
Runs, no brakes, interior needs gutted, needs new top, paint...want to rebuild transmission and engine to give it more power.
Where should it all start?
Nam Labrat
Received 4,178 Likes
Start at the most unlikely spot..........the BRAKES!
That way......you'll be able to stop the car when the interior is done as you will need to "try it out"...LOL
But seriously......make sure the brakes are rebuilt first....no sense in tuning the engine in order to drive through the neighbor's yard.
While it's on jackstands rebuild the suspension.
bballboy06,
I'd guess the answer all depends on what you want the finished product to be. If you just want a daily driver, the engine needn't be gone through; just a tune-up. And like doorguner said, brakes must be inspected and rebuilt if needed first. If you're somewhat a purist like me, you'll want about a year's time, 10 grand, patients, and lotza help from this forum.
Just curious; What Color Code is on the metal ID tab, near the Driver's Upper Door Hinge? Was this car originally white?
Steve
Steve
bballboy06,
Steve
Steve
Looks like a great car; I like 74's. As others have said, make a plan. You need about $20K... Where to start? Frame, suspension, brakes. That's your foundation.
What about a plan like this:
1. Remove Engine/Transmission
2. Suspension rebuild
3. Brake system rebuild
4. Engine bay clean-up
5. Rebuild engine/trans
6. Interior
6.Paint
6. Interior
6.Paint
416 Trim is Medium Saddle Leather (I envy you), but the 80L Paint code has me a bit mystified.
STeve
Same as my corvette , except for exterior color and mine has AC
Have fun fixing it up , I really enjoy mine
OK so here is an update with the rebuild..... Everything has been sand blasted, all U-Joints replaced, and all new bolts for everything. New brake lines, new E-Brakes, and new gas tank with all new sending unit and new bushings. New shocks.
Now i will get the rear wheels back on and move to the front suspension....I also need to finish the installing the new master brake, and brake booster.
Update:
Had Engine Rebuilt
Rebuilt brake system
rebuilt Steering
Started interior
Finished Cleaning and painting engine bay and Frame
Fixed wiring issues
Replaced all bulbs
Fixed Spedo & Tach
Painted dash pads to match and fixed vents
rebuilt Steering
Started interior
Fixed wiring issues
Replaced all bulbs
Fixed Spedo & Tach
Nice progress .
Did you bore the block .30 over , did you reuse the heads ?
Was the old cooling system trash?
Do you know what the rear axle ratio is yet ?
Mine is a 3:36
Mine is a 3:36
Update on the 74:
Completed carpet install
Installed new seats
Installed all new dash upper and lower sections
New Radio/speakers.
Troubleshooted ground issues
Troubleshooted lighting issues
Troubleshooted vaccum issues
She runs and drives great.
All electrical works, headlights work & pop, all bulbs replaced interior/exterior. New tires and rims.
Ready for new top & paint.
Softop work to happen soon.
Paint will happen soon gathering quotes.
Installed new seats
New Radio/speakers.
